Gear cutting basics help needed.
Home Forums Workshop Tools and Tooling Gear cutting basics help needed.
Viewing 23 posts - 26 through 48 (of 48 total)
  • #592534
    Anonymous
      Posted by ian voller on 02/04/2022 10:02:37:
      …books just don't do it for me
      Ah, that explains quite a lot. smile
      ian voller
        @ianvoller79273
        Suffolk born and bred, strong in the arm thick in the head. face 1
        #592551
          Posted by ian voller on 02/04/2022 11:27:28:
          Gear design is difficult. The designer not only has to cut the right number of teeth, but the teeth have to mesh with another gear without jambing, and, especially in a clock, with low friction. The other problem with poorly shaped gears is they wear rapidly.
          Low friction and wear requires the flanks and valleys have to be curved in a particular way, the idea being the teeth roll over each other rather than bump and grind.
          In days of yore, the gear wheels used in mills, were shaped approximately and they ground themselves to a moderately efficient shape. On first fit, the mill would be stiff and underpowered. After running for a while, the teeth would wear closer to the right shape and the mill would run free at full power. Unfortunately, the teeth rarely settle into the exact shape needed, so they wear rapidly. For that reason the teeth in traditional mills were usually replaceable.
          Clockmakers were first to put effort into finding an optimum curve. Mathematically, it's a hypocycloid, and understanding what that is allows really good gears to be made. The maths are difficult and were cracked in the 16th Century by the Italian genius Gerolamo Cardano. Still a steep learning curve for non-mathematicians.
          Later, it was realised that the Hypocycloid curve is inferior for most purposes to the Involute, described by another genius (Huygens), a century later. Apart from clocks, almost all modern gears are of Involute form. Clockmakers firmly believe hypocycloids are best for gearing up light mechanisms that don't transfer power. In contrast, involutes have several advantages: including being best for transmitting power and easier to make accurately. Unfortunately another steep learning curve.
          Controversial view: I think satisfactory clocks can be made with involute gears. (SoD puts Tin Hat on and retreats to bunker.)
          Ideally, a clock design would provide an exact recipe!
          • Hold a disc of diameter x in a rotary table,
          • set the dividing plate and clock-hands up to count the required number of gears
          • Put a module cutter of given size in the milling spindle
          • Cut n teeth
          This is OK as long as the tools are affordable. ( Just because a child needs shoes 'She Who Must be Obeyed' often makes a silly fuss about 'Man in Shed' spending another few hundred quid on more toys!) However, most of the theory can be avoided unless you have to roll your own using one of the other, cheaper, methods.
          I think most of us have to mix book learning with hands-on before machining makes sense.
            Posted by SillyOldDuffer on 02/04/2022 13:10:23:
            Not particularly controversial, Dave … that view has been exercised several times on this forum.
            BUT __ Involute gears don’t play very nicely with Lantern Pinions
            Edited By Michael Gilligan on 02/04/2022 13:18:36
            #592564
            roy entwistle
              @royentwistle24699
              Don't forget that in a clock the wheel is driving the pinion. Not an ideal situation.
              Roy
              Note to Ian. If using Thorntons or Bergeons cutters, the bore of the cutter is 7mm.
              Edited By roy entwistle on 02/04/2022 13:55:39
              #592594
              Simon Williams 3
                @simonwilliams3
                Am I right in thinking that the reason involute gears aren't used by and large in clocks is that the very small pinions (6 and 8 teeth) beloved of compact clock designs need undercut teeth to follow the correct involute shape. Undercut teeth are weak and impossible to cut with a rotary milling cutter, they have to be planed.
                Fact or fiction?
                By the by, I built a clock using 20 DP involute gears – that was the set of cutters I had available. To be strictly accurate I was building the 12:1 gear train from the minute hand to the hour hand on the local church clock, so space wasn't an issue. The minute hand is driven by a synchronous motor rotating once per hour, and obviously the hour hand is coaxial. Thus the 12:1 reduction driving the hour hand is equivalent to the back ear on a lathe headstock a la Myford etc. As I say, space was not a consideration but longevity is a point of honour!
                #592596
                  Have a look at this thread, Simon : **LINK**
                  https://www.model-engineer.co.uk/forums/postings.asp?th=141778
                  It’s one of several that include a link to an excellent essay on the subject.
                  Ref. http://www.csparks.com/watchmaking/CycloidalGears/index.jxl
                  … and be sure to follow the link from there to Richard Thoen
                  http://www.csparks.com/watchmaking/CycloidalGears/RichardThoen.xhtml
                  Edited By Michael Gilligan on 02/04/2022 17:48:22
                  #592612
                  Martin Kyte
                    @martinkyte99762
                    Posted by Simon Williams 3 on 02/04/2022 16:55:14:
                    What you describe is a gearbox rather than a clock. I would say the use of involute gears for your application is totally appropriate. In a clock the train from the power source to the escapement is geared up not down which is where the issues of friction arise. Tower clocks in general have lots of spare power and space and have the luxury of massive frames. Involutes could be usefully employed on the lower end of tower clocks as can steel or cast iron gearing.
                    regards Martin
                    #592627
                    Simon Williams 3
                      @simonwilliams3
                      My thanks as ever to Michael Gilligan, whose recommendations for further research by the student proved to be fascinating and educational.
                      Best rgds Simon
                      #592752
                      ian voller
                        @ianvoller79273
                        PP Thorntons site askes you to select module and leaves? Putting "Gear leaves" into google just shows green leaves face 1 is "leaves" the tooth count? The site also doesn't show bore size, anyone know what it is?
                        #592766
                          Posted by ian voller on 03/04/2022 18:28:51:
                          Not a clockmaker myself, so not expert on their jargon. However pretty sure a leaf is what an engineer would call a tooth.
                          I dimly recall the term comes from the petal shape gear teeth become on small diameter gearwheels, what clockmakers call pinions.
                          My memory is terrible, I should have mentioned before that another book worth buying is Stan Bray's "Making Clocks".
                          roy entwistle
                            @royentwistle24699
                            As stated earlier bore size is 7mm. ( 02/04/2022 ) You only need leaf count for pinions, all wheels use one cutter
                            Roy
                            #592772
                            ian voller
                              @ianvoller79273
                              thanks so I need an R8 arbour that will take a 7mm bore cutter, more expense.
                              #592773
                              ian voller
                                @ianvoller79273
                                Sorry double post for some reason
                                Edited By ian voller on 03/04/2022 20:19:39
                                #592778
                                John Haine
                                  @johnhaine32865
                                  As you mention R8 I assume you have R8 collets. No need to buy an arbor (note spelling), you can make your own. Start with say 12mm steel, turn down a length to 10mm, stepping down to 7mm for the cutter, either with an M6 threaded portion for a clamp nut or an M6 threaded hole for a clamp bolt. Make sure the 10mm and 7mm parts are to accurate size and turned without removing from the chuck. Part off from the parent stock, mount in an R8 10mm collet. I'm sure you can work out the lengths.
                                  #592779
                                  John Haine
                                    @johnhaine32865
                                    Oh, and you'll need to make some arbors to mount the gear blanks on too.
                                    #592784
                                    bricky
                                      @bricky
                                      I have made two regulators in the past and I made my own fly cutters from broken centre drills and mounted in a cutter bar made from stock.This cutter bar can be mounted in the mill.In my case I had two revolving centres with the cutterbar mounted between centres with a pulley attached driven from a motor at the rear, as the lathe is not fast enough for a fly cutter.The Myford dividing head was set at an angle on a adjustable milling slide and driven over the cutter.I never bought any cutters for either clock.
                                      Frank
                                      #592788
                                      ian voller
                                        @ianvoller79273
                                        Thanks John yes I have ER32 imperial and metric collets, 6mm bolt it will be, my old Acorn lathe doesn't do metric threads.
                                        #592792
                                        ChrisLH
                                          @chrislh
                                          In response to Simon Williams 3, for involute gears using standard hobs (20 PA) the minimum number of teeth for satisfactory meshing is 10. However as for all gears with less than 20 teeth, the gear diameter would need to be increased above the usual (T+2)/DP.
                                          I was told by an ex Smiths employee that, at one time, they made clocks using involute gears.
                                          To accomodate the limitation on tooth numbers imposed by the involute system most clock gear trains would of course need to be redesigned.
                                          As an aside, gear pumps have been made using gears with only 8 teeth but these were made using special involute hobs of 25 PA (?) with non-standard cutting depths.
                                          Although clock and watch gears are referred to as Cycloidal, I believe they are only approximately so. For example, it seems unlikely to me that the inner part of the contact faces of 6 leaf pinions (the hypocycloids), which are straight in practice, are theoretically so.
                                          But I'm no expert so please feel free to put me right.
                                          #592803
                                          John Haine
                                            @johnhaine32865
                                            Actually, the straight dedenda of both pinions and wheels are the only part of the so-called cycloidal tooth forms that actually are parts of hypocycloids! The addenda curves are circles or segments of circles.
                                            If you use Mike Cox's spreadsheet for designing button cutters it's relatively easy to find non standard pressure angles that permit small tooth counts without undercut.
                                            #592804
                                              Posted by John Haine on 04/04/2022 07:31:13:
                                              True yes
                                              … as noted in Mr Sparks’ essay, to which I referred earlier.
                                              Martin Kyte
                                                @martinkyte99762
                                                Hi Ian
                                                In horology a leaf is a tooth.
                                                If you click on Wheel Cutters instead of pinion cutters you will be able to select what you need. Pinion cutters vary in shape according to the number of leaves (teeth) on the pinion. Wheel cutters will cut any number of teeth. As you are making latern pinons you do not require any pinion cutters. I've put a link to wheel cutters below if that helps.
                                                I know there is a trend to advocate involute tooth shape for clocks but as you will deduce from the above there are practical advantages in using cycloidal not least that you only require ONE cutter for all wheel counts from 17 to infinity. Another is that fly cutters are simple to make.
                                                regards Martin
                                                #592809
                                                  For those curious about the Lantern Pinion: **LINK**
                                                  Lantern pinion as a special case of cycloidal gear
                                                  Edit: __ I’ve just found this : https://youtu.be/dCeBCR0-lr0
                                                  Part 4 is about making the lantern pinion
                                                  Edited By Michael Gilligan on 04/04/2022 09:20:40
