Thanks Jason,
Hanning in his designs made maximum use of his set of 8DP gear cutters that he had no doubt invested a lot of money in. But on the full sized engines you find that each of the shafts have a different DP. On a 2" model this will normally be 9DP, 8DP and 7DP. The result of this 'bodge' to use the same DP gear cutter is to change the centre lines of all the shafts and be warned they do not necessarily move at right angles to each other. So be aware that correcting the number of teeth to make a gear chain that looks much like the original is not an easy task, you will need to change the 2nd shaft location and assuming it is a Fowler the 3rd shaft location. Having said that having all the gears of the same DP is instantaneously recognisable to any rivet counter.
You cannot run a 12DP gear with a 8DP gear the profile is totally wrong. Also a 11 tooth gear cannot be cut with a standard gear cutter: the minimum number of teeth using a standard gear cutter is 12 teeth . You might want to look to buy a commercially hobbed 11 tooth gear once you have worked out which DP you want.
Which engine are you looking to build?
Jo
P.S. My own BB1 design is only out by one tooth on one gear from the original Fowler BB1 gear chain
I am looking for somewhere to post my full BB1 build (where I retain full rights to the copyright of the posts ) if anyone can suggest a suitable location
