I am building a 6 " Burrell traction engine and I would like to cut the gears myself,
It all seems straightforward enough, however I have one question,
The two sliding gears on the crankshaft are 25 and 34 teeth 6DP,
A no.4 cutter will cut 26 – 34 teeth,
and a no.5 cutter wil cut 21 – 25 teeth,
Could I get away with the no.4 cutter to cut both gears, ?
Or is it important to only cut the amount of teeth recommended for each cutter ?
Richard.
