Gear Change Wheels for a Smart & Brown Model A lathe
Home Forums Beginners questions Gear Change Wheels for a Smart & Brown Model A lathe
Viewing 25 posts - 1 through 25 (of 33 total)
  • #539107
    DG
      @dg43147
      Hi
      I have a Smart and Brown Model A lathe, and I need to cut a 1/2” 10 tpi, 2-start Acme thread. With the current standards gear train I have, it will not allow me to cut a 5 tpi thread, so I need to do some calcs and fit different change gears to give me 5 tpi. The lathe leadscrew is 6 tpi.
      If anyone knows a supplier of gear change wheels for S&B lathes, I would be very grateful. I dealt with a Company called ‘Bracehand’ some years ago, but I don’t think they are still trading.
      kind regards
      David
      DG
        @dg43147
        #539141
        Pete Rimmer
          @peterimmer30576
          Hi David,
          What tooth counts do you have on your end gears? The one on the stud and the one on the gearbox. The large idler is of no consequence.
          Pete.
          #539156
          old mart
            @oldmart
            I have cut 6 and 5 tpi threads on the Model A by doubling the leadscrew speed. With the speed doubled, for 5 tpi, the settings are for 10 tpi. Normally the input and output shafts rotate at the same speed, I believe the gears are 48 teeth each. I made some major modifications when I got hold of a metric MOD1 gear with 125/127 teeth. All of the gears were changed for metric ones so the complete original imperial pitches were still available, plus some coarser pitches, and all the common metric pitches as well.
            You will need to get a couple of gears with, say, 30 and 60 teeth to use to double the speed. The Model A uses 24DP, 20PA, 3/8 TO 1/2" wide, with a 3/4 bore and 1/8" keyway. Some machining will be needed. I was concerned with the link pin in the input shaft breaking with the additional stress of the coarser pitch and substituted a solid pin temporarily and was extremely carefull not to lose concentration and have a pile up.
            #539171
            DG
              @dg43147
              Many thanks ‘old mart’ for that information, that’s most appreciated. I’ll set off in search of those gears and then look at proceeding with the next stages of you guidance. Once again many thanks, that’s helped me out a lot!
              kind regards
              Davis
              #539172
              Clive Foster
                @clivefoster55965
                DG
                Don't know about the Model A but when wanting to complete the metric conversion change gear set for my 1024 VSLI was able to get suitable gears from HPC. The flat, PG, style were almost identical to the factory gears. Merely a few thou thinner.
                Obviously I had to bore out the supplied centre hole to mach the lathe studs and cut a keyway.
                Not cheap but overall of acceptable cost.
                #539173
                DG
                  @dg43147
                  Hi Clive
                  Many thanks for that. I’ve just checked on the HPC website and see they are based in Chesterfield which is only about 45 mins away from me, so I can pop over and have a chat with them.
                  Kind regards
                  DG
                  #539175
                  old mart
                    @oldmart
                    The teeth count is not vital, 32/64, or 34/68, or anything that will fit. You can check the DP of your gears with one of the online calculators, the diameter of the 120 teeth idler is all you need.
                    https://www.technobotsonline.com/gear-size-calculator.html
                    Edited By old mart on 11/04/2021 17:18:15
                    #539177
                    DG
                      @dg43147
                      Excellent…once again many thanks for your guidance!
                      #539218
                      Chris Crew
                        @chriscrew66644
                        Probably not so important when just cutting 5TPI with a 6TPI lead-screw, but the advice when cutting threads coarser than the lead-screw is to drive the head-stock from the lead-screw, rather than driving the lead-screw from the head-stock, although I would take a few more lighter cuts just in case.
                        I do this when cutting multi-start worms or even a worm of a larger DP to relieve the stress on the change-wheels. I am not mathematically or technically competent enough to calculate the actual stress on the gear teeth or at which point they would fail, but I take the advice given by Cleeve and Law et. al. for doing this.
                        It is no great pain to wind the lead-screw by the hand-wheel when cutting relatively short threads or worms but it could be if the thread is longer. I have jury-rigged up a reversible motor, reduction box and sprocket drive to the lead-screw of an ML7-R because you obviously cannot dis-engage the clasp nuts when cutting pitches that do not contain factors of the lead-screw thread.
                        #539237
                        DG
                          @dg43147
                          Many thanks for that piece of sound advice Chris, duly noted!
                          kind regards
                          DG
                          #539395
                          old mart
                            @oldmart
                            Thats an interesting thought, Chris, the model A could easily have a QD handle at the end of the leadscrew, like some Myfords. Even easier for me, as I bought a spare Norton box together with leadscrew and feedscrew, plus the end bracket, cheap, no one else was interested.
                            Edited By old mart on 12/04/2021 19:07:12
                            #539468
                            DG
                              @dg43147
                              Hi Guys
                              just to go over the gear train configuration for a 5tpi thread form, and looking at the rules for change gears again:
                              This on L.S 6 36 ( Mandrel wheel)
                              —————- = — X 6 = —
                              Thds to be cut 5 30 ( Leadscrew wheel)
                              Would also work ok?
                              #539525
                              DG
                                @dg43147
                                It looks like my gear formula didn't quite come out, apologies for that, but basically I was just trying to ascertain that the correct mandrel and leadscrew wheels required to cut a 5 tpi thread, with a Leadscrew of 6 tpi works, by applying the formula, which would give a mandrel gear to be 36T and the leadscrew gear would be 30 tpi. I have had a quotation from HPC Gears for both these gears, and the ones previously advised in the previous forum ‘thread’, only I just need to be 100% sure before I commit to the order, that I choose the right combination for the job in hand. Sorry to be a pain!
                                many thanks
                                DG
                                #539528
                                Bazyle
                                  @bazyle
                                  You never answered Pete's initial question of what gears do you already have. I would add to that 'what is the standard gear configuration on a Model A' ? You could probably use some other settings of the qcgb and maybe only have to buy one gear.
                                  #539530
                                  DG
                                    @dg43147
                                    Apologies, I forgot to go through the ‘Forum’,….I emailed directly to Pete with the following info:
                                    (Top) mandrel gear. = 48T
                                    (Middle) idler gear. = 120T
                                    (Bottom) leadscrew gear. = 48T
                                    Thanks Bazyle
                                    DG
                                    #539534
                                    old mart
                                      @oldmart
                                      Don't worry about the 6tpi leadscrew, it will only make the calculations more difficult. The standard gears are 48-120-48 so adjusting the gearing to double the output speed will simply double the original pitches from 8-72, to 4-36. I'm sure you would have looked in the righthand door, that is where the change gears would have been originally stored, although the gears were an optional extra.
                                      #539537
                                      DG
                                        @dg43147
                                        With the standard arrangement that I already have, would just buying an additional 40T gear wheel, for the leadscrew drive, in conjunction with the 48T mandrel gear that I already have, give me a 5tpi?
                                        DG
                                        #539557
                                        old mart
                                          @oldmart
                                          If you want to set 8tpi and get a 5tpi cut, the leadscrew speed must be increased by a factor of 1.6. If you buy a 30 tooth gear to use as secondary, that will work with the primary 48 tooth to give the correct ratio. 48-120-30. This would be the cheapest way to go.
                                          #539559
                                          DG
                                            @dg43147
                                            Many thanks ‘old mart’, I’ll go ahead and
                                            place my order the 30T wheel!
                                            DG
                                            #539578
                                            old mart
                                              @oldmart
                                              Don't forget, always make the first cut very light, so you can double check the pitch is right. I made that mistake with the model A once when I set a thread pitch in the wrong position and had to puzzle out why the nut would not screw on.
                                              #539580
                                              DG
                                                @dg43147
                                                Noted! thank you for your help.
                                                DG
                                                #539673
                                                Howard Lewis
                                                  @howardlewis46836
                                                  Unless I have misunderstood, the objective is to cut a 5 tpi thread on a machine with a 6 tpi Leadscrew., and then to cut a second one, 180 degrees out of phase, to produce a double start 10 tip thread..
                                                  If so, the ratio between Mandrel and Leadscrew needs to be 1.2 :1 so that the Leadscrew rotates slower than the Mandrel, Suggesting a 50:120:60 set up, or something similar..
                                                  If the machine has a Norton box, find the settings that give a 1:1 through the box. (Which would be for 6 tpi ) and use changewheels to give a 1.2:1 reduction..
                                                  30:120:36, 40:120:48 or whatever takes your fancy, using the wheels that are available.
                                                  #539685
                                                  DG
                                                    @dg43147
                                                    Yes Howard, that’s precisely what I want to achieve.
                                                    DG
                                                    #539695
                                                    Howard Lewis
                                                      @howardlewis46836
                                                      Have you got wheels that will allow you to achieve a 1.2:1 ratio simply?
                                                      If not you will have look at using a compound gear as an idler, to get the 1.2:1. ratio.
