A review of the above post.
After inquiring about water cut frames for the gauge 3 Dee the following errors emerged.
The overall length of the main frames is given as 15.625″ but if the individual dimensions at the bottom of the frame are added together, the overall length works out at 15.7195″
On the tender frames the length is 11.063″ but the individual dimensions give 11.064″
The tender dimension is only a thou out but which dimension is correct on the main frames.
