Posted by JasonB on 18/09/2016 19:36:16:
Liquid gasket works for me. Teflon baking sheet works for others
You say that you drilled the stud holes in teh gasket? this may well leave a ragged edge which won't help with tearing, they are better punched out either with a Wad (hollow) punch or a punch and die (4mm peg and 4mm hole in die)
Edited By JasonB on 18/09/2016 19:39:10
+1 for punch and die, they don't need to be hardened, in your case make die cylindrical, 7mm OD, 4mm hole, hold it in drilling vice, grind the non cutting end of a 4mm drill so it has sharp corners, then fit the gasket to the cover and use it to position the holes, poking the punch through the holes in the cover
Edited By duncan webster on 19/09/2016 11:55:18
