The usual for silver soldering where you want to get the whole assembly upto temperature fairly quickly is Propane with a burner of around 7Kw. Although MAPP burns at a higher temp the torches are smaller so overall heat output is less.
The starter Sievert sets have the right size burner, mate with a 4bar regulator
You can do a bit of Sif brazing with a torch like that provided the section of the metal is not too great otherwise it won’t get hot enough.
For things like studs you probably want a more localised higher temp probably oxy propane but I’ll leave others who have the kit to advise
