Historically, dehumidifier manufactures have had a ‘standard’temperature, on which they base their sales pitch.
That standard temperature used to be as high as 30 Celsius, where compressor types (the only type made) were really most effective, so gave advantageous collection rates. They rarely stated the testing temperature, of course!
However, testing temperatures have, more recently, been reduced to 27 degrees and even more recently to 21 degrees by which?. The compressor faction do not like that and have complained to Which?. They reckon dehumidifiers are left running for long periods and that desiccant types waste power, compared to theirs.
The industry admit that compressor types lose efficiency as the temperature falls and are effectively inoperative at around 5 degrees Celsius, while the desiccant type continue to work at the same afficiency down to about 1 degree Celsius.
Dehumidifiers UK **LINK** compare the real running costs and reckon compressor types have an approx 20% running cost advantage at 21 degrees on water removed from the room. This running cost difference obviously reduces as the temperature falls and at some temperature below 20 degrees there is parity, then desiccant types are cheaper to run, per amount of water extracted.
My workshop needs a dehumidifier in the winter, almost universally, when the temperatures drop lower than 10 degrees. Clearly, for me, a desiccant type dehumidifier is king for my situation. I need the heat to warm the workshop slightly while the humidity is controlled at an adequate level. The workshop machinery must be maintained above freezing point, or condensation of moisture in the air will condense on it.
I also disregard the idiot desiccant proponents on u-toob that are not clever enough to realise that simply raising the temperature will lower the RH! That means that each situation needs due consideration. For proection from condensation at lower winter workshop temperatures, I think the desiccant type are the best – as long as the workshop is completely draught-proof. Mine costs me no more than about 80p per week and less than 70p on average in the winter months. I may use supplementary heating while I am in residence, mind – the machines may be cold, but the air temperature rises quite quickly, with a minimum of 100mm insulation on nearly all wall and ceiling surfaces.
