Garador door closer
Garador door closer
Home Forums The Tea Room Garador door closer
  • #562771
    Peter Bell
      @peterbell11509
      We have a Garador auto M2 garage door closer which has worked faultlesly since it was installed. However it now often will not open, switching the mains off/on resets it and it works but often it puts 4 on the display when it wiil not work.
      Needless to say the manufacturer says replace the complete unit at around £300
      Has anyone sucessfully repaired one or got any fault finding info of the unit or circuit board?
      Thanks
      Peter
      Peter Bell
        @peterbell11509
        #562773
        pgk pgk
          @pgkpgk17461
          Presumably all rails, tracks, bearings are smooth and clean and lubed and all contacts and limit switches checked? Is there an interpretation for that fault code?
          pgk
          #562775
          Bill Davies 2
            @billdavies2
            This guy has an M2 (same type or compatible brand?) and code 4 indicates overload, sugessting some lube required/corrosion or whatever, ditto pgk's comments.
            Garage door controller
            Compatible brands
            Bill
            #562776
            Peter Bell
              @peterbell11509
              Yes its all running fine/smooth on the mech side.
              Working in the garage earlier with eth door open it put 4 on the display and stopped working after a few minutes without being touched or moving.
              I'll have to explore the unit more.
              #562787
              Grindstone Cowboy
                @grindstonecowboy
                Just a guess, but if it wasn't doing anything when the 4 came up (and if 4 actually does indicate overload on your model), then presumably it was (silently) still trying to open the door. Which would point to the OPEN limit switch and/or the associated wiring being suspect.
                The father-in-law's door opener had a fault which the fitters reckoned needed a new control unit to repair, but which I tracked down to a reed switch in the limit switch circuit – cost of replacement less than £1.
                Hope this helps.
                Rob
                #562792
                Peter Bell
                  @peterbell11509
                  Thanks for the helpful comments.
                  When it was stopped the unit had clicked off. I've put my clamp on meter on it and switching off fine. Transformer Volltage is 27v but dc to the motor dips as expected on load but a cap on the board is getting very hot. Its only 470uf which seems a very small value for a smoothing cap.
                  If nothing else reckon I've found a wasps nest!
                  Peter
                  #562797
                  Howard Lewis
                    @howardlewis46836
                    Not an electronics man, but maybe, the capacitor is the cause of your problems, by leakage current causing the overload, and the heating?
                    Might be worth replacing it, for what it costs, possibly under a tenner.
                    #562800
                    john fletcher 1
                      @johnfletcher1
                      That capacitor shouldn't be even warm, electrolytic capacitors age and dry out and then become in effect a series resistor, hence the heat. Have a look on RS, Farnell, Rapid, ESR for a replacement and look out for the continue band along its length that is the negative, got to get it soldered in right first time. I have some where a complete door system, motor, arms and I think two hand sets etc, was all working when my friend moved to a double garage bungalow.? Might you be interested ? John
                      #562811
                      Oven Man
                        @ovenman
                        I have a similar problem on my garage door opener of a different make. I suspect that the problem on mine, and may be Peters, is that a current sensing resistor has gone a bit high. The control panel appears to be standard and the various settings are held in an EEPROM. Being like Peter I am reluctant to just pay for a replacement unit. I have got round my problem by bypassing the control unit with a push switch to manually open it. Closing can be done using the hand sets as normal. It's been like this for about six years now. It could probably be sorted by adjusting the values in the EEPROM by I haven't got a clue how to go about that.
                        Peter
                        #562828
                        Peter Bell
                          @peterbell11509
                          Thanks for even more helpful comments.
                          Changed the capacitor, it measured 220uf down from 470uf. Now doesnt get warm but I dont think thats the problem. I can make it display a 5 for overload if I hang onto the door while its moving. but my fault is 4 while its standing doing nothing.
                          Maybe quite a sophistcated unit with suspected pwm to slow the door as it's nearing the end stops. Think these are set as part of the installation if I remember correct. As its probably some microprocessor problem dont expect its easily fixable so another unit to try maybe a better option. Maybe manual operation is an easier option! This is a 550Nm unit, the ones on ebay are 1000Nm so probably quite old.
                          Thanks for the offer, shall I send a PM John?
                          Peter
                          #562830
                          kevin laxon
                            @kevinlaxon28008
                            some doors have rf transmitters bottom & top for end sensing,these normally have fairly well hidden AA batteries in units on the inside of the door,it may well be that the batteries need replacing hence no end of travel sensing,has to be worth a look!!.
                            #562838
                            Grindstone Cowboy
                              @grindstonecowboy
                              If you can locate a manual, there should be instructions on setting up the travel – on some it's just a matter of getting it into "learning mode" by a combination of button presses and then opening and closing it a number of times.
                              +1 on Kevin's suggestions of batteries in RF sensor units, too.
                              Rob
                              #562853
                              Peter Bell
                                @peterbell11509
                                Thanks for the suggestions but no sensors or batteries (hidden or otherwise) on the actual door also no batteries in the unit, its all mains powered. The fault appears and it stops working witout moving or being touched, only a mains switch off/on gets it going again.
                                But it's worked this morning!
                                #562863
                                pgk pgk
                                  @pgkpgk17461
                                  Still sounds like an overheat self-protection? Any components old enough to be in sockets rather than directly soldered? Worth contact cleaning?
                                  I used to have a laptop that needed regularly taking apart – in that case due to the fans sucking Dalmatian hair into the thing …
                                  pgk
                                  Edited By pgk pgk on 15/09/2021 08:04:42
                                  #652244
                                  John Sykes 1
                                    @johnsykes1
                                    I've just repaired one of these if it's still relevant!
                                    Peter Bell
                                      @peterbell11509
                                      Thanks John.
                                      I eventually solved my problem by putting it on a timer where it was turned off early morning every day before it was needed so effectivley reset every day and it worked well for some months until the plastic chain tangled itself up and that was the end of that so bought another off ebay.
                                      Handy things—when they are working!.
                                      Peter
