Well assuming they are not including the handle on the steam valve then it's only 1/4" shorter than the Gamages which was quite small and fiddly. For example the drilled steam passages to either end of the cylinder were only 1.2mm dia.
I'll see haw it scales and maybe go for 12mm bore rather than 7/16" which would just make it a touch larger.
