Posted by Michael Gilligan on 30/04/2022 23:35:32:
We all know, I hope, that there is a risk of galvanic corrosion when stainless steel and Aluminium are in contact.
But what is the ‘corrosion product’ ?
From what I understand, it's perhaps not really a corrosion product, but a result of a process – maybe thats the same thing??
Al in contact with stainless, supplied with a suitable electrolyte ( dirt, air acids, mists, salt, etc) results in the electrons migrating from the Al to the stainless, weakening the Al in the region, and converting Al to Alumium oxide. This in itself is not the problem, as Al oxide is a non-conductor and so the immediate interface corrosion ceases. It does however continue deeper into the Aluminium. And therein lies the problem Al oxide occupies a much greater volume than the pure Al, and so the S/Steel fixing is nicely locked in place, as in a Vise-grip…
There is mention of Copperslip being a no-no, or any copper in contact with Al – But as I know it, is copper not in fact less of a no-no than stainless – But I am not sure what is an 'Active' and a 'Passive' Stainless steel – Or is it that a 'Passive' S/Steel has been passivated in an acid bath?
If I have it correct, the closer in the table two materials are, the less the co-valency problem? Copper is closer than 'passive' stainless…
Does not really help you Michael, but rather interesting.
Stainless / Al must be a problem though, since every 3-5 years I hold in my hand one of my window closers, the aluminium window frame having corroded completely away around the closer's stainless steel fixing screws – 50meters from the Atlantic ocean so lots of salt about.
Have you measured continuity tween screw and body? if none, then the oxide has filled the space completely – then you could perhaps try electrolysis – fill the cavity with salt water and apply a voltage to get current flow for a few minutes and see if the screw loosens – reverse the polarity and repeat?
- Magnesium
- Magnesium Alloys
- Zinc
- Beryllium
- Aluminum Alloys
- Cadmium
- Mild and Carbon Steel, Cast Iron
- Chromium Steel (With Less Than Or Equal To 6% Chromium)
- Active Stainless Steels (302, 310, 316, 410, 430)
- Aluminum Bronze
- Lead-Tin Solder
- Tin
- Active Nickel
- Active Inconel
- Brass
- Bronze
- Copper
- Manganese Bronze
- Silicon Bronze
- Copper-Nickel Alloys
- Lead
- Monel
- Silver Solder
- Passive Nickel
- Passive Inconel
- Passive Stainless Steel (302, 310, 316, 410, 430)
- Silver
- Titanium
- Zirconium
- Gold
- Platinum
