g71 stock removal
g71 stock removal
  • #345864
    geoff adams
      @geoffadams14047
      hi all
      g71 stock removal
      I have seig kc4s cnc lathe it runs on a Chinese version of fanuc the manual is something else totally useless
      iam trying to use g71 to machine from a 45 mm dia bar down to 28.5 dia by 28 in length in .5 cuts this is the code I have written as far as I understand it
      idont understand how it knows what dia to start from the finish dia is in the code
      t0101
      g0x50z5 move to safe zone
      g71u.5r4. depth of cut .5 retract 4.
      g71p100q2oou0w0f50 block nos for profile no finish cuts
      n100g0x29
      n200g1z-28f50
      g0x50z5
      m5
      m30
      where am I going wrong
      thanks Geoff
      geoff adams
        @geoffadams14047
        #345867
          How are you going to get a 28" bar into a lathe with 14" between ctrs?
          #345872
          geoff adams
            @geoffadams14047
            Jason its mm sorry if that wasn't clear its the principle 0f g71 I need to understand
            #345878
            Baz
              @baz89810
              Geoff have a look on practicalmachinist.com/needG71info. Seems there are two sorts, one line and two line, from what I remember you start at first cut diameter in X with clearance in Z
              #345882
              michael warren 1
                @michaelwarren1
                Hi if your stock size is 45 mm i would rapid move to G00 X 46. M08;coolant on, then rapid move to G00 Z1.; Then G71P101Q102U.2W.1D.5F.2: this will leave .2 on the diameter and .1 on the face for a finishing cut, it will take a .5 depth of cut at a .2 feed rate, then the following.. N101Z1.G00X28.5; (diameter required) G01G42Z0.F.1; (turns tool nose compensation on and feeds to Z0.also finishing cut feed rate.1) G01Z-28; (feeds to Z-28) G01X45.5; (feeds up the rear face) G40; (tool compensation off) N102; G70P101Q102; (finish cut amount left on in G71) M09; (coolant off). G00X200.Z300.; M30; may make a bit of sense.
