Dykes rings are a really venerable design.
Modern materials and processes should make them perform even better than when they were first invented.
Before I retired nearly twelve years ago, it had been common practice to have compression rings narrower than the groove depth so that they were gas backed. We found that the ring gap had a big effect on blowby..
The secret was to have a cold fitted gap so small that, when hot (full load rated speed coditions) the ring ends did not butt together. If they did, you were certain to have bore damage and broken rings.
The blowby tended to improve as the engine bedded in, as the rings lapped themselves to the faces of the groove.
Quite a contrast to have a three ring pack that performed much better than the five ring packs of the sixties and seventies, in terms of both blow by and oil control. The better technology , based on experiences, made that possible.
Some "new" things actually ARE better, not just in the minds of the marketing men.
