I'd suggest starting the CAD work with a revolved protrusion. You sketch a centreline then draw half the cross section. The convex and concave ends should be drawn on this sketch for least complication later. However, if the carb bowl shape allows it I would suggest making the concave end flat, as that will be a far better shape for the eventual 3D print, to be placed on the bed of the printer.
One thought about printing a float in polypropylene – if you print a closed volume solid shape the print will need to have an internal support honeycomb structure (called infill, in the slicer program) to allow printing the top end plate / dish of the float. This would need to be as minimal fill as possible, biggest possible spaces between honeycomb walls to be sure the float would still float.
Second thought about printing a PP float – if the honeycomb structure proved to be too heavy after a float test, you might consider making a two piece float, like a cup and lid, or two shorter cup shaped pieces joined in the middle like traditional drawn brass float parts. The issues with this are the joint will need sealing and must have reliable fastening. a snap fit could be designed in and would give good fastening but would likely not seal well. Glue or sealant could be used but it would need to be gasoline / petrol proof and also virtually no glue will provide a strong permanent bond with PP or PE or nylon parts, as the surface energy is just too low. (now waiting for the armchair experts to say "this glue will sort of work on PP" or "do corona treatment / laser etch before gluing" or other magic solutions – these do not work, in my experience having been tasked with joining PP and PE parts in industry many times. If there was a solution for gluing PP and PE strongly, industry would be using it, believe me.) A rubber o-ring could possibly be designed into the groove of a snap joint but the ring would add weight and the extra plastic of the joint itself would add weight. Heat staking or ultrasonic assembly might work to join and seal the PP parts but it requires special equipment and may not work with 3D printed parts. The layer to layer bond in 3D prints may not stand up to the force of heat staking or the vibration/force of ultrasonic welding These processes do work very well with injection moulded PP or PE or nylon parts though, if the shape of the joint is designed carefully.
All the above considered, I suggest carving the float out of Nitrophyl foam or similar, or making it out of brass shim stock formed and soldered in the traditional way may be better solutions in the home shop to make a float.
If doing one in brass shim stock, 3D printing could be used to make really nice form tools to stamp convex / concave ends. Absolute minimum of solder is needed for the brass float assembly naturally, to keep weight to a minimum.
Just food for thought. Hope the ideas help.
Edited By Jeff Dayman on 25/02/2021 14:51:00
