From Across The Pond
Home Forums Work In Progress and completed items From Across The Pond
  • #618003
    Jack Bodenmann
      @jackbodenmann56018
      Hello My Friends
      I'm trying to figure out how to post some photos. Im afraid I'm not the brightest bulb on the tree with such things.
      Jack
      Jack Bodenmann
        @jackbodenmann56018
        #618006
        Grindstone Cowboy
          @grindstonecowboy
          Hello Jack
          Advice on posting photos can be found here.
          Rob
          Links to https://www.model-engineer.co.uk/forums/postings.asp?th=103028&p=1
          #618011
          John Hinkley
            @johnhinkley26699
            Welcome, Jack,
            Another couple of hints: If you use a 'phone for photography, make sure you use it in landscape orientation otherwise your photos may well end up rotated. To avoid this happening, upload them first into an image manipulation program on your computer and use the "save as" function to save them as jpegs with a suitably descriptive name. "My lathe" is so much easier to understand than "DSC00458" or somesuch.
