Frog 500 Glow motor
Frog 500 Glow motor
Home Forums I/C Engines Frog 500 Glow motor
  • This topic has 13 replies, 7 voices, and was last updated 16 May 2017 at 12:28 by Graham Williams 5.
  • #293910
    Graham Williams 5
      @grahamwilliams5
      Picked up a couple of model aircraft engines from a flea market yesterday, an Elfin 249PB, beam mount, and a Frog 500 glow-motor, at a good price, wasn't expecting much. Elfin is locked up so soaking away in solvent. Frog came apart OK but big end of con-rod badly oval so will need to make another, otherwise it looks like it might be a runner, screw heads and fins etc. not butchered. Can anyone help with accurate hole centres for the con-rod please. Quite a bit of info on the web but not that dimension. Cheers Graham W.
      Graham Williams 5
        @grahamwilliams5
        Con rod dimensions
        #293922
        Speedy Builder5
          @speedybuilder5
          Cross section x stroke = cc, so
          stroke = cc/area of the piston
          #293923
          Hacksaw
            @hacksaw
            Sadly only have a 349 diesel…but I saved it from my mates skip ! surprise
            He has 2 petrol Mighty Midget ? engines of his late fathers he would part with…. reconditioned , with invoices from a long time ago , and never used….
            #293936
            SteveW
              @stevew54046
              Stroke not same as con rod length. You do need a rod or estimate from the old one?
              #293949
              Graham Williams 5
                @grahamwilliams5
                Possibly 1 3/8 inch but wanted to be sure before I started on a replacement.
                #294001
                TobaccoBurner
                  @tobaccoburner
                  With some measurements from the engine and the timing info from here (page 121):-
                  http://rclibrary.co.uk/files_titles/1561/Model_Aircraft_1950_05.pdf
                  it should be possible to compute (or measure from a cad drawing) the required length.
                  Am part way through a similar exercise with a DC Spitfire. Having settled on a dimension I ran an animation in Fusion360 to check if it made sense. Now just need do final assembly, find a prop and then we see whether I got it right.
                  #294030
                  D Hanna
                    @dhanna35823
                    Have you got a dimension yet? If not I han pull one apart and measure for you.
                    #294034
                    Graham Williams 5
                      @grahamwilliams5
                      No, haven’t got a dimension yet, that’s a very kind offer, would be greatly obliged. Cheers Will
                      #294039
                      not done it yet
                        @notdoneityet
                        All you need to know is the protrusion (or not) of the piston and the stroke. The rest is then easily calculated from the parts in hand.
                        I read the interesting history, by Adrian Duncan, of that engine. i see there are copies, spark ignition and glow plug variants, and the later replicas had slightly different dimensions (metricated). Piston to head clearance may be the most important tolerance.
                        If a petrol variant (these were convertible to glow plug) it would appear you may have a quite rare and more valuable version.
                        #294041
                        D Hanna
                          @dhanna35823
                          The one I have has a centre distance measured over a big end pin of 0.2187 and little end of 0.1875 = 1.395" . Maybe a bit of ovality but should get you somewhere near the mark. You can have this one unless you want to make one for the fun of it! Just pm your address if you do want it.
                          DH
                          OZ
                          #294048
                          Graham Williams 5
                            @grahamwilliams5
                            PM's sent guys
                            #294054
                            D Hanna
                              @dhanna35823
                              Posted by Graham Williams 5 on 19/04/2017 11:57:51:
                              PM's sent guys
                              Returned pm. In the mail tomorrow for youwink
                              #298409
                              Graham Williams 5
                                @grahamwilliams5
                                Just sat in the workshop looking at the Frog 500 I picked up recently, holding another con rod sent all the way from OZ. I can only say that the generosity of people using this forum, either with advice, or in this case providing a scarce part is pretty overwhelming. smiley. Thanks to everyone but particularly Dallas.yes
                              Home Forums I/C Engines Topics
