Freeing up a domestic paper shredder. A novel use of WD40?
Home Forums The Tea Room Freeing up a domestic paper shredder. A novel use of WD40?
  • #36571
    Greensands
      @greensands
      Greensands
        @greensands
        I have found that an excellent way of freeing up and maintaining a domestic paper shredder is simply to spray WD40 onto the cutter blades, paying no particular attention in controlling exactly where it the goes into or onto the working mechanism. Works wonders!
        #564024
          Mine came with a squeezy bottle of special lubricant
          Bought it years ago … still going strong.
          Edit: My post on this page confirms year of manufacture 2006
          https://www.model-engineer.co.uk/forums/postings.asp?th=132802&p=16
          Edited By Michael Gilligan on 23/09/2021 18:33:05
          #564036
          Anonymous
            Posted by Greensands on 23/09/2021 17:55:08:
            I Works wonders!
            Smells nice too. wink
            #564039
            Grindstone Cowboy
              @grindstonecowboy
              I find the GT85 spray in the red, black and white cans (sometimes on offer in Aldi) has a lovely, slightly floral smell. Coincidentally, I came across a can of Wurth aerosol lubricant that smelled exactly the same, so I suspect there may be some "badge-engineering" taking place, as the Wurth was over twice the price for a smaller tin.
              Just to bring this back on topic, I have dismantled a couple of shredders, and there's very little in the cutter area that could be damaged by lubrication, so spray away!
              Rob
              #564065
              Nigel Graham 2
                @nigelgraham2
                I lubricate mine by soaking a sheet of paper with the oil, rather than spraying the machine.
                I do have a bottle of Fellowes "Performance Oil"… special stuff then: shredders, paper, for the use of.
                A little research revealed it is something called Canola Oil. Pardon? Never heard of the Canola plant.
                It turned out to be no more than rapeseed-oil, so when the Fellowes bottle's empty I'll know what to use.
                #564070
                  Posted by Nigel Graham 2 on 23/09/2021 23:10:01:
                  Not just any old rapeseed-oil though: **LINK**
                  https://en.wikipedia.org/wiki/Canola_oil
                  MichaelG
                  #564075
                  Anonymous
                    Staples sell lubricant sheets for this purpose which seem to do a decent job without the mess.
                    #564158
                    Nigel Graham 2
                      @nigelgraham2
                      Ah. Special rapeseed-oil then, Michael!
                      I expect "3-in-1" would work just as well. Possibly better because vegetable oils tend to turn to a horrible sticky goo!
                      #564176
                      Vic
                        @vic
                        I use camelia oil on ours from time to time, seems to work ok. Soaked into a sheet of paper as Nigel said above.
