Free lathe riser/stiffener heavy steel channel
Home Forums Materials Free lathe riser/stiffener heavy steel channel
  • #29752
    Russ B
      @russb
      Russ B
        @russb
        There are getting thrown out, but I see uses for them in the home workshop as lathe bed stiffeners/raisers to add a bit of extra mass – these would be sturdy enough to twist a bench top size lathe bed true if need be (up to Myford 7 / Boxford AUD sort of size)
        Obviously they could be used for all sorts of seriously heavy duty work, a bearing press is another good example. There is also a stack of 10+ slightly smaller section stub length around a few hundred mm long.
        Getting thrown in a skip this week or next, I could hang on to them for a little bit if need be.
        2 painted grey U section RSJ 200×75, 12mm webs, 6mm thick across the 200mm width. Both 1050mm long.
        1 unpainted 200×95, 15mm webs, 8mm thich across the 200mm width 1620mm long, flame cut at one end.
        any takers for one/all, must be collected from DN2 4SE area in Doncaster – all very heavy obviously.
        Edited By Russ B on 20/09/2017 12:31:31
        #317832
        Russ B
          @russb
          #317843
          Antony Powell
            @antonypowell28169
            I'll take them off you
            could collect on Monday on the way home from Birmingham
            Thanks
            Tony
            #317940
            Antony Powell
              @antonypowell28169
              Hi Russ
              can you message me the collection address & a contact number
              thanks
              Tony
              #317947
              Russ B
                @russb
                Tony, sorry i think it's gone, someone local is collecting, I'll let you know if it falls through
                #317948
                Ady1
                  @ady1
                  Looks seriously useful (drool)
                  If you're cutting it up with a hand held angle grinder I have found that long straight lines work best with thick flat stock
                  So I would go in the back, and cut a 1mm deep long channel across the width
                  Then 2mm, then 3mm etc etc, (seems to be much easier than "going straight through"  )
                  Once through the back you can lop the end bits easy peasy
                  Edited By Ady1 on 21/09/2017 09:51:22
                  #318077
                    12" of that would be just the job to build a bespoke machine on like a gear hobber or a grinder.
                  Home Forums Materials Topics
