My point was NOT about the projection. In my sketch I drew third angle but first angle would show the M Evans drawing defect just as well.
My point was that the sharp trimmed edge should be as close as possible to end of the front flange where it runs to zero. It should not be shown notched in the side view as on the M Evans drawing. If it is notched, the copper of the front face will run out to a small point which will likely disappear during silver soldering, leaving a hard to fill, weak hole on each side of the boiler in its weakest area. If flanged all the way to the top, it will transfer the soldering heat better, reduce chances of a meltaway and be far stronger due to greater soldered area. This is my LAST comment on this.
Another point I just noticed re the regulator. I belive it is intended to be slipped into the boiler from backhead end and screwed into the 5/16-40 threaded bush on the front tubeplate. My questions on this and other regulator questions below.
1. No thread is called out on the small end of the regulator. Regulator body is called out 7.5mm dia at rear flange, or .295″dia , small for later making a 5/16″-40 thread.
2. If it is intended to be threaded at the boiler front end and screwed to the bushing, how would we make it steam tight? just pipe dope? (a gasket can be used at the backhead end on the reg flange, but I don’t see a sealing feature, ie flange, cone, step, pipe sealnt callout etc. at the front end.)
3. ‘balancing’ holes are shown on the top side of the regulator but no drain holes are shown on bottom. Drains front and back on the shaft side are suggested otherwise there will always be water laying in the shaft hole, which over time may cause corrosion.
4. 20 steam inlet holes are specified at #66 dia (0.83mm). This gives a total area of about 11 mm squared for steam inlet. Great, but the outlet hole is 2 mm dia or area 3.14 mm squared. Do we really need 20 inlet holes? I guess the intent may have been to stop droplets entering the small holes, but not sure this will be effective in practice. Probably better to use a high inlet pipe in a steam dome. A tapped hole in the reg body would allow the dry pipe to be assy’d after the reg was installed in the boiler.
JD
