Free Electricity
Free Electricity
Home Forums Electronics in the Workshop Free Electricity
Viewing 25 posts - 1 through 25 (of 40 total)
  • #391382
    Speedy Builder5
      @speedybuilder5
      Yes we all know that you there is no such thing as electricity for free and in the attached youtube video, the magnet passing between the two spark plugs is generating some electricity, but there is no circuit ! What is going on, and how can a LED bulb which normally functions off 240volts AC can run off what I assume is a low voltage. Come on you brain boxes – what's happening. Ps skip through most of the video as its a bit boring.
      There are a number of similar views, I saw one with a couple of ball bearing races, a couple of small motors etc – that was pretty impressive too.
      https://www.youtube.com/watch?v=z2q_UwD2bvE
      Edited By Speedy Builder5 on 16/01/2019 15:27:56
      Speedy Builder5
        @speedybuilder5
        #391383
        Journeyman
          @journeyman
          The interweb is awash with videos of similar nature, perpetual motion and the like. They all owe more to nifty video editing than they do to scientific principles. You are without doubt being had over wink
          Ady1
            @ady1
            There are some other videos around showing you how the trickery is done
            They're quite clever
            If it looks too good to be true etc applies
            #391386
              And the Earth is flat…
              #391389
              not done it yet
                @notdoneityet
                LEDs only need a forward voltage of 0.6V (the usual silicon type) and most are only rated for 250mW at the max, so it won't take a great deal of energy to light it faintly.
                Try neons in your microwave to find if the microwave distribution is up to scratch (need something else, as well, in there to absorb the radiation). Works a treat.
                Edited By not done it yet on 16/01/2019 15:59:53
                #391390
                Journeyman
                  @journeyman
                  Posted by Neil Wyatt on 16/01/2019 15:48:34:
                  Well, of course it is:-
                  not done it yet
                    @notdoneityet
                    Posted by Journeyman on 16/01/2019 15:59:53
                    What/ No flying pigs!
                    #391393
                    Journeyman
                      @journeyman
                      NDIY, The great A'Tuin entertains no pigs (except of course The Hogfather)
                      vintage engineer
                        @vintageengineer
                        There was a rumour that someone in America built a huge coil under a powerline to create inducted electricity. Don't know if it would work?
                        #391398
                          A 40W equivalent LED light bulb only needs about 5W of power at 3Vdc approx and the electronics in the bulb are a simple power supply that drops mains down to that value. The bulb itself is easily dismantled and it would be possible to hide a battery and a reed switch (these are operated by a magnetic field) inside the holder. In the video I think the switch is hidden under the wooden board between the spark plugs – we never got to see that side!
                          A much smaller LED than 5W would create the effect of a lit bulb. My guess is a smaller LED was used, this type from amazon are 3V at 20mA. Lighting one is an easy job for a couple of AA cells. (I see you get 100 of them for £1.31 too, postage free!)
                          Either the video is a fake or all our energy problems are over!
                          John Haine
                            @johnhaine32865
                            I have read a report published by a US research organisation on methods by which amounts of power sufficient to run clandestine radios by special forces could be derived. One method involved a long loop of wire running parallel to an overhead power line. For example one leg of the loop would be under the line and the other some distance away, the length being hundreds of metres. Enough magnetic flux can link the loop to generate useful power in the right conditions, watts rather than kW, but enough. One leg could be an existing run of wire such as a strand of a wire fence.
                            But a large coil directly under a power line won't link any useful flux, it needs some asymmetry.
                            #391401
                            Anonymous
                              The original T&Cs for my amateur radio licence, back in the 1970s, banned end-fed wire antennas longer than, I think, 75 feet. That was because in the early days of radio people near the long wave transmitters were extracting enough energy to power a light bulb or two.
                              #391416
                              Brian G
                                @briang
                                In this house we obey the laws of thermodynamics!
                                Edited By Brian G on 16/01/2019 18:20:05
                                #391427
                                Mike Poole
                                  @mikepoole82104
                                  A friend carefully removed the cap of a bayonet cap lamp and broke the glass to remove the filament carrier. He then fitted a torch bulb and battery inside and wired it to the two terminals and refitted the cap. Shorting the terminals with a finger ring lit the lamp with no wires to be seen, of course it did need to be a pearl type lamp to hide the trickery.
                                  #391429
                                  mgnbuk
                                    @mgnbuk
                                    Not so – I get up to 3Kw totally free when the sun shines in summer & up to 2Kw in winter.
                                    I just let a company called A Shade Greener fill the south facing side of my roof with solar PV panels – they own the panels & are responsible for maintaing them for 25 years. They get paid the Feed in tariffs & I get to use all the electricity they produce at no cost. At the end of the 25 year period (when the Fits end) they give me the installation FoC, so totally free electricity.
                                    Nigel B
                                    #391446
                                      Posted by Journeyman on 16/01/2019 15:59:53:
                                      Naaah!
                                      It's Turtles all the way down!
                                      #391447
                                      not done it yet
                                        @notdoneityet
                                        Not so free if and when you wish to sell your house. The legalities, etc likely cost the vendor thousands. These rented roofs are a minefield for potential house purchasers. Far better to install your own kit and avoid the third party renters of equipment. They will go mostly go out of fashion when the FIT scheme finishes in a couple of months time. Doubtless they will come up with some other money spinning scheme…
                                        #391450
                                        FMES
                                          @fmes
                                          RF Energy ? two aerials and a sig gen off screen, bit like we used to get flourescents lighting up under a pylon.
                                          #391472
                                          Danny M2Z
                                            @dannym2z
                                            When I was a young radar mechanic a friend put a fluorescent tube up in a gum tree and showed what happened when the x-band radar antenna was pointed at it.
                                            A fairly narrow beam, 1MW pulses at a PRF of 1100 Hz (used to track mortar bombs).
                                            We used this to spook the gunners with our magic lighting system.
                                            Another trick was to plug an electric shaver into a tree trunk and have a shave. Battery powered razors were a new invention in those days so most artillery people had never heard of them (mid '70's)
                                            * Danny M *
                                            #391476
                                            Geoff Theasby
                                              @geofftheasby
                                              Running clandestine radios from a large wire loop laid under a power line doesn't sound very clandestine to me. Also, one could detect the use f a superhet receiver by listening for its local oscillator, TV detector van style.
                                              #391477
                                              John Haine
                                                @johnhaine32865
                                                Geoff, if one leg of the loop is an existing fence and the other thin black covered wire in the undergrowth, and it's in the middle of nowhere, it's will be quite hard to spot. And the kind of radios they will use are "clandestine " so I guess they think about things like LO radiation. I have no idea if this is actually used, it was a research project. In WW2 the SOE used Stuart Turner Sirius powered generators run from wood fired boilers, I expect you could see and smell the smoke. Nowadays you'd probably have a solar panel to charge a battery.
                                                My point was simply that you can extract energy by inductive coupling to a power line but it ain't necessarily easy.
                                                Edited By John Haine on 17/01/2019 07:08:04
                                                #391480
                                                Speedy Builder5
                                                  @speedybuilder5
                                                  Another trick, a cup of water in the microwave, and a filament bulb beside it. Run it at 750watts and the bulb lights up – look, no wires! Hardly "for free" though.
                                                  #391485
                                                  Robert Atkinson 2
                                                    @robertatkinson2
                                                    There is such a thing as free electricity (in the UK). As long as you own an electric or plug-in hybrid car and your employer lets you charge it at work. HMRC changed the rues last year and it's no longer a taxable benefit.
                                                    Robert G8RPI.
                                                    #391488
                                                    mgnbuk
                                                      @mgnbuk
                                                      Both my neighbours had the panels fitted by A Shade Greener shortly after I had mine installed & both subsequently sold on. The first had a bit of a gripe from the Halifax BS, but A Shade Greener put an additional clause in the contract that allowed, in the event that HBS re-possesed the house, that ASG would remove the installation without charges if requested to do so – a "backstop" in current parlance, I suppose. Neither my original or new neighbours suggested that this had cost them any extra. With so many of this type of installation (ASG had over 10,000 at the time I saw a TV report about them moving out of their original area into ours & got in touch with them), arrangements will be made to accomodate them when properies get sold.
                                                      At the time of installation, the arrangement we have would have cost around £18K so, for me at the time, an outright purchase of my own installation was not possible. Installation costs did come down a lot as numbers of installations increased, so several years later owning my own may have been an option. As it is I generate around 4500 kwh a year, for which ASG receive (IIRC) 42p per kwh FiT & I get to use the electricity FOC – what I can't use at the time it is generated feeds back into the mains.
                                                      Nigel B
