Hello everyone.
I have recently acquired a Fowler-Bowers bore micrometer, size 5/8 – 3/4", along with a 0.7497" setting ring.
Trying to set the gauge up with the setting ring according to instructions for a similar Bowers non-digital micrometer (model XT, although the one I have is an earlier model). Question is, is it possible to adjust the reationship between the '0' position on the thimble and the line that co-incides with the .625" etc index mark on the barrel? There seems to be some mis-alignment currently that to my mind will make it difficult to interpret the readings taken.
Having bought it from eBay, if there is a fundamental problem with it (i.e wear or damage) that is causing the mis-alignment, it will be possible to return it after consultation with the seller.
Any assistance appreciated.
Anthony
