Four Jaw chuck
Four Jaw chuck
Home Forums Workshop Techniques Four Jaw chuck
Viewing 25 posts - 1 through 25 (of 37 total)
  • #453832
    Vic
      @vic
      Is not my favourite work holding device but sometimes needs to be used. I often find it such a PITA to set up and today was no different. As the part to be re machined had a hole in it already I hung the work on a suitable rod held in a drill chuck in the tailstock and then carefully tightened the jaws of the four jaw. This got me much closer than I had been and within ten minutes of tweaking I lucked out when the DTI read 0.02mm TIR. As the part was not too critical I accepted this and machined the part. I couldn’t help thinking though, would you four jaw experts out there have generally accepted 0.02mm or would you have tried to get as near to zero as possible?
      Vic
        @vic
        #453835
        Emgee
          @emgee
          If the accuracy required is fulfilled it must be a good job, no point in chasing NASA tolerances.
          Emgee
          #453837
          pgk pgk
            @pgkpgk17461
            I'm no 4-jaw expert but my accuracy would depend on the part and job – no point chasing unnecessary microns for the sake of it.
            Having said that if the part was a decent shape as opposed to some weird irregular pentagon then i quite enjoy getting the 4-jaw close and 10 mins seems quite a long time so worth reviewing some of the tips on the subject – such as taping pieces of flat scrap to a rectangular bar and indicating on the inside of the overhang as being quicker than having to keep pulling the dti jaws back to get around external corners. Or indeed indicating on a rod in that hole if needs to be central.
            pgk
            #453859
            Former Member
              @formermember19781
              #453864
              Clive Brown 1
                @clivebrown1
                Some while back, following a tip on this forum, I made a 2nd key for my 4-jaw, a simple, short affair out of mild steel. This enables 2 opposing jaws to be adjusted in conjunction with each other. It's amazing how this speeds and eases the job of accurately centering a workpiece. Wish I'd made it years ago.
                #453867
                Former Member
                  @formermember19781
                  #453872
                  old mart
                    @oldmart
                    I have been meaning to make two extra keys for the 6" and 160mm four jaw chucks for some time, having often heard of the improvement in dialing in. It pays to practice getting a four jaw chuck spot on, the work is held more securely, especially when parting off.
                    As for accuracy in setting up, it always depends, although, more than once, halfway through machining something, I have kicked myself for not getting the first chucking spot on when I had the chance.
                    Edited By old mart on 23/02/2020 20:43:20
                    #453873
                    JC54
                      @jc54
                      +1 for two chuck keys. John
                      #453885
                      old mart
                        @oldmart
                        I usually sit the dti on the cross slide if it needs to be moved about when setting up, and moving the saddle and cross slide speed up the rough adjustments, otherwise it sits on the bed.
                        #453901
                        Martin Hamilton 1
                          @martinhamilton1
                          If you go to Youtube & put in centering a 4 jaw chuck, there are some great very fast & accurate ways of centering a 4 jaw very quickly. I use these methods all the time now.
                          #453903
                          Hopper
                            @hopper
                            The key (pun absolutely intended!) to using a four jaw chuck is to be super-methodical.
                            Use the dial indicator to measure runout and also use the dial indicator to measure exactly how much you are moving the job at each adjustment. It should be exactly half of the runout.
                            For the last thou or two (.02mm or two) you can get the desired movement by tightening the jaw on the high side without needing to loosen the jaw on the other side first. A surprising amount of movement occurs this way.
                            With a bit of practice you will be able to get things running true within a thou"/.02mm in about three adjustments.
                            #453911
                            thaiguzzi
                              @thaiguzzi
                              World 4 Jaw Championship.
                              Watch Keith Fenner vs Adam Booth, true 4 jaw artists.
                              #453946
                              Vic
                                @vic
                                Ok, it seems like I have another job on the list – make a second chuck key!
                                What do most of you prefer for clocking the piece, DTI or Dial gauge?
                                #453950
                                Martin Kyte
                                  @martinkyte99762
                                  One of my most used 'tools' is a sprung (spring?) centre which makes setting up to a centre pop/centre hole very straight forward in the 4 Jaw. Easy to make too. I also have a dial guage that lives in a QC tool holder which also saves faffing around. Never bothered with a second chuck key.
                                  regards Martin.
                                  #453956
                                  JA
                                    @ja
                                    Posted by Martin Kyte on 24/02/2020 11:32:30:
                                    regards Martin.
                                    Matches my set-up except that the dial gauge still lives in its box. However its mounting has had its own QC tool holder for over ten years.
                                    JA
                                    #454008
                                    old mart
                                      @oldmart
                                      I prefer to use a lever type indicator rather than a plunger. If the stock is square or rectangular, I just use the tool to touch the corners and see the marks made, or the gaps left.
                                      #454011
                                      Martin of Wick
                                        @martinofwick
                                        Centring work close to the chuck at a half a thou is straightforward. The real fun starts when you have a slightly longer piece that needs to be set concentrically at both ends.
                                        That when you find out how good your chuck is or how much patience you have!
                                        Edited By Martin of Wick on 24/02/2020 16:46:31
                                        #454261
                                        larry phelan 1
                                          @larryphelan1
                                          Never bothered much with the 4 jaw until I had to, then I began to see its real value.
                                          Now I use it almost all the time, no real trouble to set up and much better results than the 3 jaw, none of which are dead on.
                                          #454273
                                          Howard Lewis
                                            @howardlewis46836
                                            An extremely useful accessory for a lathe, or rotary table.
                                            Allows you to provide better concentricity than a 3 jaw, or allows work to be done deliberately off centre.
                                            No end of uses to which it can be put inn the workshop.
                                            #454279
                                            Andy_C
                                              @andy_c
                                              A really good article on setting up a 4 Jaw Chuck is in MEW Mar 2016 pages 68-69. To get better than a few hundredths probably requires a second go around but it is a methodical method that might suit and once used to it is quick and effective.
                                              #454309
                                              old mart
                                                @oldmart
                                                The Toolmex 6" four jaw I have fits easily on the 6" rotary table, especially as there are four slots.
                                                #454316
                                                Gordon A
                                                  @gordona
                                                  Search for Joe Pieczynski onYoutube. He has a clever way of setting rectangular stock in a 4 jaw chuck.
                                                  Gordon.
                                                  #454357
                                                  Neil Lickfold
                                                    @neillickfold44316
                                                    To indicate stock accurately with the 4 jaw chuck, I like to use Aluminium or brass pads ,between the jaws and the work piece. These do 2 things, prevents damage to the work piece, and allows an area to squash up a little to allow you to get the very last little bit out of the alignment of the part. In general it should be quite easy to get a part indicated to 1 thou , especially when you pre dial with 2 short keys. Then use the main key for the final micro adjustment. Realise that some jobs , just require light cuts to get the best results over all.
                                                    Sometimes using 2 dial indicators can make the setting up of a part much quicker.
                                                    Hopper
                                                      @hopper
                                                      Posted by Gordon A on 25/02/2020 20:44:06:
                                                      Gordon.
                                                      Doh! That is so amazingly clever — and simple! (But its for square stock, not rectangular, that I saw.)
                                                      I just had to share it. Check this out. Cut to the chase at the 1:40 mark.
                                                      Edited By Hopper on 26/02/2020 09:52:05
