The Atom version is pretty well cut down, so check the comparison table carefully. The Pro and Expert versions are £940 and £1540 respectively and if you want to use any of the non-basic features, that's what you'd be looking at.
And £475 for a basic 2.5D CAM option, described as "A modelling and milling package tailored for sign makers, hobbyists, makers and students". Not much use if you put it up against modern multi axis packages. The Fusion CAM is actually HSMWorks, used professionally in many sectors. If you plan to get into CNC at any time, think about it now.
Once you've got the hang of one of these CAD systems, it's not difficult to learn another one. However, I wish I hadn't had to go through the process so many times along the way, each time investing dozens of hours in the process.
Despite the shallow accusations of tribalism, I'd suggest you take a look at Fusion 360 which will cost you nothing and is a very capable, professional system, with full feature 3D CAD, simultaneous multi axis CAM, FEA simulation (stress, thermal, vibration etc), rendering, sculpting, sheet metal, 2D drawing etc.
Right, I'll duck again now…
Murray
Edited By JasonB on 14/11/2018 15:39:13
