Thanks for replies – interesting. They have given me focus for some further research.
It seems that the new forum software allows multiple quotes in replies, so here goes:
I would assume that they got tired of units being returned as faulty when they were not. If it was not really a problem why would they be saying it?
The refrigerant has been changed from the previous ozone destroying version and it’s probably less effective.
You are a more trusting soul than I am! I think they might be saying it to persuade me to spend more money than I need to. Currys say that certain freezers are unsuitable for use in an unheated area. The ones that they explicitly endorse are from Beko’s https://www.beko.co.uk/lifestyle/freezer-guard Freezer Guard range. Beko actually say “Did you know that when some freezers or fridge-freezers are used in an environment below 0°C it can cause them to stop functioning? ” No mention of ‘unheated areas’. I suspect there may be some of marketing-speak going on with Currys, To give them credit, Beko are clearer – they give numbers.
I’m missing something here…
- For a freezer, the gas at the compressor inlet is likely to be at about -18°C. If it isn’t, your food is going to become inedible rather rapidly, in the UK, temperatures below -18° C are incredibly rare.
- For the condenser to be covered in ice is not a problem under any conditions, the condenser will reject heat into ice better than it will reject heat into air.
I can believe that combined fridge freezers with only a single pump will fail to work correctly if the ambient temperature is lower than the fridge’s set point, also that a fridge with butane as the refrigerant will fail to work if the ambient temperature approaches 0°C, although in that case, the food will be well within the desired temperature range even if the fridge is turned off.
I do have a dehumidifier that will not work at low temperatures, and had a heat pump clothes dryer that had the same issue, but they are both relatively high temperature heat pumps, with different refrigerant requirements than freezers have.
Can anyone shed further light on this?
This is pretty much where my thinking is. The problem with combined fridge/freezers is pretty obviously to do with the thermostat being located in the fridge compartment, so if that gets cold enough the compressor will never switch on.
After Noel’s revelation that the most common refrigerant for freezers is butane (actually isobutane, or R-660a as they call it, just to obfuscate clarify things) I’m leaning towards the idea that the refrigerant is the crucial thing. But I too would welcome any further light.
Thanks again for replies, Robin.
