Fobco 7/8 pillar drill
Home Forums Beginners questions Fobco 7/8 pillar drill
  • #11011
    Roert Knight
      @roertknight66084
      belt size ??
      Roert Knight
        @roertknight66084
        Hi
        Anyone out there know the dimensions of the belt for a Fobco 7/8 pillar drill?
        Mine has completely disintegrated, and all I can find on the web are bespoke ones costig £25-35. I think (but may be completely wrong) that they're in the A50-A55 range. Any advice gratefully received.
        Thanks
        #569607
        Dave Halford
          @davehalford22513
          For “A” Belts (1/2” width) subtract two-inches from the outside measurement to select the correct V-belt. For example, if the outer measurement is 48-inches and you subtract two inches then A46 is the size..
          Nit so easy when the belt is broken.
          Edited By Dave Halford on 03/11/2021 17:24:14
          #569611
          Ian Parkin
            @ianparkin39383
            My drill has a A56 fitted
            #569631
            lee hawkins 1
              @leehawkins1
              Hello
              How about these
              stores.lathes.co.uk/parts/fobco-7-8-10-8-drill–drive-belt
              #569637
              not done it yet
                @notdoneityet
                I would measure the pulley diameters and distance between centres (max and min) – then toddle along to my local belt supplier and they would supply a suitable belt. Mine (ABC), would likely provide me with a choice to try, if marginal, and I would return the unused one.
                #569661
                John Baron
                  @johnbaron31275
                  Hi Guys,
                  My FOBCO uses an A56 belt ! I got mine from Motorsave, about £7.00p a couple of years ago.
                  #569683
                  Roert Knight
                    @roertknight66084
                    Thank you all so much! I signed up very recently, and learned more in a couple of hours from your replies than after a couple of days googling and ringing round stockists etc,.
                    A fascinating website.
