I have been busy on my current project, a horizontal steam engine – 1 1/2 inch bore and 2 1/2 inch stroke.
Tackled the flywheel yesterday which was set up on a face plate so the actual 'casting' ran true (not the OD) All went well, it turned really well, then I turned it over clocking the now turned OD only to find the two halves of the casting were not registered together very well!
I am faced with filing the casting so the inside diameter of the spoke section runs true (not eccentric) or I have temporarily bolted it to my rotary table to true the inside diameter up with an end mill?
Not happy about either way but something needs to be done as it will not look good – and be out of balance – its a big flywheel 7 inch OD and 1 5/8 inch thick
Does the rotary table method sound my best option?
Alan
