One of the options given was to to use concrete but if you would like the weight to be heavier for its size, add lead or steel to the mix.
One of the companies which I worked for manufactured industrial cranes like the ones on building sites but much bigger and the cost of cast iron or steel for the counter weights was expensive. The weights were more than 20 tonnes each. They were made by casting concrete using steel as the aggregate. Mainly from the discarded pieces remaining after punching parts from steel plate. The smaller the parts, the better because you can pack in a higer proportion of steel. For the flypress weight you could use any small metal objects, nuts, bolts, lead fishing weights, etc. Use concrete, polyester resin, builders joint filler or other bonding agent to hold the casting together.. The mould coukd be simply a childs plastic ball.
Paul
