Hi,
I'm using Silver-flo rods and Easy Flow flux to connect pieces of mild steel.
My heat source is a 1/2" Bullfinch torch fed from a 7kg Propane cylinder.
So far so good you might say, and very often it is. The flux forms a silvery appearance and the Silver-flo rod runs nicely into the joint.
But …. every now and then the flux goes black and the Silver-flow beads up and the joint doesn't make.
At this point I have to scrape off the black residue, clean up the metal again and hope for the best.
What am I doing wrong?
I've tried using a Borax flux with the same results.
regards
B
