Flow Drilling Using Friction
Home Forums Workshop Tools and Tooling Flow Drilling Using Friction
  • #17396
    “Bill Hancox”
      @billhancox
      “Bill Hancox”
        @billhancox
        I love this one. Whether or not it has a modelling application is arbitrary. It is nonetheless a super slick process.
        OldMetaller
          @oldmetaller
          Wow! No more turning boiler bushes! angel
          John.
          #153481
          Keith Hale
            @keithhale68713
            The process has been around some 30 years. Initially it was called T-Drilling and produced an external collar. It produces joints ideal for producing strong leak-free joints by silver soldering – close tolerance and parallel.
            Is it a good technique – certainly and particularly on sheet and square tube. Round tube ?
            Is it viable for the model engineer? Depends on the cost of the drill bits.
            One source of boilers stumbled across the flow drilling phenomenon by accident and considered a patent. But we have all used a blunt drill at some point!
            Keith
            #153482
            Roderick Jenkins
              @roderickjenkins93242
              Interesting. I think you would have to give serious consideration to the metallurgy of the heat affected zone. From the video the area is getting seriously hot and then quenches – similar to welding.
              Rod
              #153496
                Flow drilling has been discussed in MEW in the past, but as it wasn't in the article title I can't find it in the index.
                colin hawes
                  @colinhawes85982
                  I recall seeing studs welded to plate using this method at an engineering exhibition. If my memory is right steel studs could be "welded" to aluminium. Colin
