Flattening tube ends.
Home Forums Workshop Techniques Flattening tube ends.
  • #105811
    Mark P.
      @markp
      Hello all.What will be the best way to flatten the ends of some 3/8" dia stainless tube to create something similar to this photo?Would I be best off making a die to do the job,I have tried squashing it in a vise but the results were not satisfactory.They are for mudguard stays on a motorbike so they will be on show,and a good finish is required.
      Mark P.
      Mark P.
        @markp
        #105812
        SteveW
          @stevew54046
          I think I'd take two short bits of angle and file a radius in the top corner. Then use them in the vice. I think you will need to experiment with a more gradual radius to get the effect you want. The bits of angle would only have to be a bit longer than the tube diameter so not very wasteful.
          As it's in stainless ….good luck!
          Steve w
          #105813
          Gordon W
            @gordonw
            Fit a suitable size of flat bar in each end, I suppose s/steel for your app. The size of bar can be found by trial and error, there is somewhere a formula for doing this but can't find it, sorry. This is the usual way to do this PS use smooth vice jaws.
            #105814
            JA
              @ja
              Many years ago, as a student, I had to flatten stainless hypodermic tube in a similar manner many times. When the tube was annealed there were no problems, You will need to experiment but heat to a good red heat and cool as slow as possible.
              JA
              #107077
              thomas oliver 2
                @thomasoliver2
                I formed the ends on some mudgaurd stays years ago and probably still have the formers. It is necessary to form a rounded end to the main tube not a squared off one , as would be obtained simply by squeezing between the vice jaws. If I remember. I made two half formers by driiling down a length of square bar, which was then sawn down in half. I then used a ball ended cutter to form the hemi spherical ends. Then the cavities were extended with a milling cutter to accomodate the flattened end. It is best tor remove all sharp corners slightly with a file. A heavy vice was used to apply the pressure. I remember that it did an entirely neat and satisfactory job.
                #107097
                Mark P.
                  @markp
                  Thanks for the replies,job now sorted.
                  Regards Mark P.
                  #107244
                  Sub Mandrel
                    @submandrel
                    I see the job is now done, but just for reference, I had to re-bend a mooring hook in 1/2" stainless steel. Heated to a red heat I was able to bend it by hand with one end in the bench vice.
                    ChrisH
                      @chrish
                      Beware of rearranging stainless steel with a hammer to get the flats – stainless gets brittle when hit and can then fracture.
                      ChrisH
