Flattening brass plates
Home Forums Workshop Techniques Flattening brass plates
  • #792082
    t1krt
      @t1krt
      I’ve removed the brass plates off my denham lathe as they have stretched and curled up and will no longer sit flat.
      Any tips on flattening them out?
      I havnt measured them but they are roughly a mm thick… vernier eyes…..
      Tia
      Bazyle
        @bazyle
        First you should consider annealing it which might introduce additional distortion.
        Have a look at clockmaking books and forums as it has been a long term problem for them. Then practice on a different sheet as it is going to be one of those almost forgotten skills that isn’t as easy as it seems.
        Obviously as I haven’t given specific instructions I have never actually flattened anything, but done plenty of the opposite both deliberately and inadvertently.
        #792096
        John Haine
          @johnhaine32865
          I have read that if you heat to nearly molten on a flat surface it will quickly flatten out.  Cool slowly
          #792098
          bernard towers
            @bernardtowers37738
            can you put them in a set of bending rolls carefully at least if you overdo it you can turn them over!!!
            #792106
            t1krt
              @t1krt
              I think you’ve given Me an idea for my first project when I get my new motor. I set of rollers.
