Thanks guys.
Sorry – context: I got a Hemmingway kits saddle lock lever for the lathe (for the sake of £10 including the handle it seemed ok).
One part is a 'bucket' type spacer that fits around the lower end of the lever:
0.75 " o/d
0.6" i/d
0.4" overall depth
0.3" bore depth (flat bottom)
and there's a 5/16" through hole through the base.
Instructions state:
– Hold in chuck
– Drill 5/16" dia. x 1/2" deep, then 1/2" dia. x 0.3" deep.
– Bore 1/2"dia. hole to 0.6" dia. with flat bottom
– Part off to 0.4"
So that's what I need to do – the flat bottom is so that it fits snugly against the spigot at the end of the lever. It's basically a big counterbore.
I know its not critical, but at this stage it's still good practice for me to follow a simple drawing and try to achieve what's specified as well as I can.
So it's clear what needs drilling and what needs boring – which makes sense – but I was wanting the best technique in terms of do you enlarge the 1/2" bore incrementally, and at the end of the bore go inwards to form the flat bottom, or start at the middle, or what?
The 0.3" drill depth obviously has to be to the tip of the drilled cone, otherwise it would always be a coned base.
BTW this is the smaller of the two boring bars I've got:
Thanks again all.
