As J H says, without smoothing capacitors and or a choke, the DC will have a ripple.
Half wave rectification will block every other half cycle whilst full wave rectification will give constant supply, but withe voltage constantly fluctuating between zero and peak, at supply frequency..
The ,inductance of the coil and hysteresis in the magnetic circuit will mean that the magnetic flux never drops to zero, so the base will stay in place as long as the forces imposed on it are not excessive..
With one coil U / S you will only have half the retaining force available, so returning the other coil to operation will be the way to go to ensure safe operation of the complete unit..
It is probably 110 Volt since it is intended for site operation from a transformer with two 55 volts windings centre tapped to earth.
