Hopper, Andrew
When it comes to reaming Oilite say :-
"Oilite bearings may be reamed provided a dead- sharp cutting tool is used. However, reaming does destroy porosity more than single point tooling."
I think it doubtful that typical Model Engineer/ Home Workshop Guy tooling will be good enough for a reamed Oilite bearing to work perfectly well over its full specified performance range and lifetime.
Which is a whole different thing to "works well enough for me in my home workshop".
Generally the things we do are very much at the light duty end of the bearing performance spectrum and actual running lifetime but a small fraction of the specified life under industrial conditions. So odds are that a significant amount of pore smearing is unlikely to make much difference to folk like us. Especially if the shaft and bearing are lubricated before installation.
I seem to recall being told that if pore smearing is sufficient to be visible using normal inspection optics the self oiling properties will have been almost completely destroyed. Sufficient sub-surface damage to affect performance can easily be done with no reasonably visible effects. I gather the engineering of and operational modes of these things is somewhat more complex than simple description implies.
Think I'd be looking for a brand new carbide spiral flute reamer if I had to ream one and be confident it would still work well.
Most of my adjustable hand reamers are essentially new and nicely sharp but I'd not trust their ability on that job. I agree that its highly likely that they would do the job well enough to produce an at least adequately functional bearing but its not the sort of chance I like to take. Especially no given the temporal investment in disassembly to get at the offending bearing and re-assembly afterwards.
Edited By Clive Foster on 29/09/2022 12:13:19
