Posted by John Haine on 28/12/2021 13:00:24:
- Was the new motor a direct fit on the motor mounting plate or was any fettling needed?
- Is there any provision for axial adjustment of the motor to help in lining up the pulleys with the headstock?
- Any tips for access and methods to tighten the set screw?
- I will have to move the lathe on its stand to get access to the motor as it sits against a wall – any suggestions as to how this can be done?
- Any other tips or advice?
Thanks in advance for any information!
1. Direct replacement, just make sure you buy the correct motor shaft size i.e. 5/8" or 20mm dia.
2. Axial adjustment isn't needed, just slide the pulley along the motor shaft to line up with the counter shaft pulley.
3. Can't comment, mine came undone easily and tightened easily with a long ball ended allen key.
4. I used a crow bar to tilt the lathe to enable me to insert some old gas barrel under the stand and rolled the lathe forward on that. Beware of over tilting the lathe as it is very top heavy.
5. Although I used a Transwave system, the principles are the same. It really is a very simple operation and you will wonder why you hadn't done the change years ago as it makes a tremendous difference to using the lathe.
Phil
