The ruled off plaster hasn't gone too badly but will need another coat so be interesting to see if a thin coat and pressure works out. Worst part is where the plaster underneath bulged out so the feather edge more or less scraped it off.
If I ever do anything like this again I'll take all of the plaster off. I did on one side but being determined to get a decent finish with plaster I didn't on one side. It's taken a day for a section to dry – sections 'cause I under estimated the amount of plaster. Twice! I was sure the one before the last would do it but the wall must have been way more out than I thought.
I just stuck some of the corner tape down with PVA. Had a problem. A 2.8m length is difficult to handle so had to cut it in half. The ends didn't behave well but managed to get away with it. I should have asked some one to hold the other end. I used the waterproof PVA with just a drop of water added to stop it drying too quickly and coined the paper down flat with the metal strip first with my finger nails. Also the edge of a scraper when it was up. It seems to have sucked down a bit while drying and looks nice and tight.
I'll make sure there is some one around when I do the other edge. Just did the one in case it didn't work out.
Not sure what to blend in with but am tempted to use board skim plaster rather than easi fill cause that is more of filler and plaster can be sanded too. This is also why I'll stick to Wickes jointer for joining tidied up with easi-fill.
I've bought a role of fibre paper having noticed a comment that it soaks up paint well. So the lot will get covered with that plaster board and all and then diluted paint or pva. It can be used directly on plaster board.
The gas work took up some time watching them. Finally one of our 2 meters is disconnected, one circuit no longer used so the meter can go. Sod then stepped in. We had a gas leak. For some reason one of flexible leads to the meter decided to leak. Rather badly. They came and fixed it within an hour of using the gas leak phone line. I did have a feeling at times that we could smell gas before the work was done. Interestingly when the meter was changed to one of the smart ones we did have a legal leak. Looks like that was the work done changing the meter and it decided to get a lot worse.
I wont be able to do any more for most of this week. Other things call that can't be avoided.
Might get to actually fitting an Ikea unit at some point. We have one to get an idea of what they are like but several will be needed for a trial fit. My wife said a while ago that she doesn't mind if the kitchen is in a mess over Xmas. It probably will be.
Edited By Ajohnw on 12/12/2016 00:03:52
