Fitting digital scales to the Wabeco 1200 vertical mill
Home Forums Workshop Tools and Tooling Fitting digital scales to the Wabeco 1200 vertical mill
  • #61799
    RJKflyer
      @rjkflyer
      Thought this worth posting – many of us probably fit the simple type digital measuring scales to our mills, but it struck me that a slightly different approach to mounting them could make them easier to use.
      See what you think!
      Edited By RJKflyer on 05/01/2011 17:36:19
      RJKflyer
        @rjkflyer
        Simple scales make life easier – but an innovative way to fit…
        #61808
          Seems a bit of a waste fitting cheap scales to a decent machine like the Wabeco
          Easier option is to use one of the remote readouts that plug into this type of scale, though they are a bit suspect as well. Mounting the scales flat like he has done also makes them far more suseptable to swarf and cutting fluids
          J
          Edited By JasonB on 05/01/2011 18:27:11
          Edited By JasonB on 05/01/2011 18:27:39
          #61810
          RJKflyer
            @rjkflyer
            Hmm, thanks for the encouragement…
            What I will ultimately move to is a Newall microsyn, but as someone who has been milling for only 6 months, I learned a lot from doing this albeit simple project and this will help me make a good job of a £1,200 DRO system when the time comes. There was little point splashing out on Mitutoyo scales if i intend to go Newall DRO later on…
            I wouldn’t waste any money trying to use some Chinese DRO on these as it’s adding rubbish to ‘cheap scales’ as you encouragingly point out!
            We all have to start at the bottom and learn up…
            #61813
              The glass scales sold by the likes of Allendale are a good half way house. Far more reliable than the calliper type scales and readouts and with the covers will be fine for 99% of hobby use.
              Thats what I now have after ditching my calliper type scales and the remote readouts (not the DRO boxes)
              J
              #61844
              KWIL
                @kwil
                I would encourage RJKflyer to go for Newall, they are excellent and the microsyn  rule is very compact. Standard bracketry is a little larger than required, see my album for a real miniature one. Nice little milling exercise.
                Edited By KWIL on 06/01/2011 11:52:13
                #61852
                EtheAv8r
                  @etheav8r
                  Richard (RJKflyer)  I applaud your efforts and ingenuity, wow for a beginner you have done really well, and if it works for you and you are happy with the results then that is just fantastic and clearly well worth the effort and expense – and only you can be the judge of that.  Be not discouraged.
                  I am a complete beginner to tis machining malarky and I have a Wabeco D6000E on order with Pro Machine Tools, and it will come ready fitted with a Newall DRO and Microsyn scales…. I am please I have got something that is regarded as good by ‘them wot knows about these things’ as I know nowt!
                  #61858
                  RJKflyer
                    @rjkflyer
                    Thanks for your encouragement! Funnily enough i took a look at the D6000E page on Emco after reading you post, and towards the bottom i spotted a picture of a digital measuring scale JUST like one i fitted to my mill!
                    However, the Newall looks absolutely first class!
                    There are a couple of other videos of mine at http://gallery.me.com/richardjkelly although they’re mill related. One’s about turning in the mill…!
                    #62287
                    KWIL
                      @kwil
                      RJKFlyer, read your PM
                      #63094
                      Jon
                        @jon
                        A bit late in a reply but how are you getting on with the little mill?
                        We had a 1210cnc about 9 years ago and couldnt do a thing with it except mill plastic and wood. You could actually visually see the upright casting flex with minimal cut on, worst £5k at time spent, got £1500 two years later unused.
                        #63097
                        RJKflyer
                          @rjkflyer
                          So far, so good. It will handle a 2.5″ carbide insert facemill across 2″ steel without the twisting you mention.
                          I suspect that its power (2 hp) could exceed its rigidity however.
