Hi All
You learn something every day…Thanks for the as always good advice.
I have spent quite a bit of time digging around the net, so far the only specifications I have found for the Taylor Hobson alignment telescope have been dimensions. I guess they regard the rest as proprietary. I did see reference to the focal length of the eyepiece? being 8 inches.
This was mentioned on one site I visited. The fixed camera eliminates parallax which can cause the aiming image to move about when you move your eye side to side or up and down. This can cause an error. Without a camera you have to adjust the device to eliminate this. In this application the mount must be solid not like some of the rather "Wonky" setups seen.
I have found a couple of videos that explain the process of Digiscoping pretty well. Both are non technical. They are focussed, sorry Pun! on nature photography using a spotting telescope. However as the first UK video makes clear all eyepieces are similar because they all have to interface with the human eye.
This one form the UK in two parts **LINK**
And this one from the US **LINK**
They both suggest that a basic camera (with a lens that is of a similar diameter to the eyepiece of the telescope) will work better then larger lens DSLR camera. The demonstrations are fairly clear. in the US video the presenter also shows a larger camera being used, he mentions it needs to be a camera fitted with a 40 to 50mm lens but not more.
Both show proprietary adaptors of varying mechanical merit, That wont be a problem for anyone reading this in here. I already have a nice piece of Aluminium waiting to be machined, once I have sorted a nice little camera.I don't know much about them also I do have a DSLR but it is big the lens will not work.
I do want a camera that can echo the image in the viewfinder LCD to a PC screen at the same time via a USB cable, maybe that is a common function. I don't Know.
I will not really need to take many photos of measurements although a record of accuracy is a nice thought, when I have the setup working I will post a photo here.
