Don't forget that the measuring beams, spars, whatever, are an analogue to digital device, with either light or magnetic bars and spaces doing the measuring. As such, there is always a +/-1 count error in this analogue to digital conversion. So, if the spar has 5 micron lines and spaces then there will be an additional +/-5 micron error. Of course if the spar has a =/-2 micron spacing then this conversion error will be 2 microns and mostly hidden in the conversion to a 5 micron readout. There might also be hysteresis error from moving one way then the other, this could be far more than 5 microns. Spars I have seen have some pretty stiff rubber seals, and the drag from them could be any ones guess.
As usual, do repeated, 20 or so, measurements and machining using something that will resolve to 1 micron, not accurate, but will resolve as a precision reading. A fiducial micrometer is the thing, not a digital micrometer where you have the same conversion error, analogue wins here. The difference between accuracy and precision, also repeatability and resolution. Easiest to machine a diameter on a lathe, from one direction, then the opposite. Measure up, bit of statistics and you have your answer. Read Right First Time by Price.
