Hi chaps, well I just connected my tina horizontal engine to my glr vertical boiler, I had fired up the boiler before (which was fun) and run the engine on air, but WHAT a difference when you put them together!!,! It's so exciting a big hissing lump of hot metal.
so not a question just wanted to share my happy dance with someone . Things I have learnt. Steam finds leaks where air doesn't (need to put a gasket on the cylinder head it leaks a little ) and I need to put a drain valve on the cylinder head to get rid of all the spluttery condensate till it gets hot.
once I have tweaked it a bit will hopefully post a wee viddy
Dunc
