Hi David!
I found that my ML7 was very sensitive about how it was fixed down, if the bed was not to be twisted.
I can thoroughly commend the Warco BH600. If it is in good condition, it will serve you well. I have had a lookalike since 2003 and it has been a very useful machine.
The BH600 used to be available in either Imperial or Metric form.
It should come with 3 and 4 Jaw chucks, Faceplate, Fixed and Travelling Steadies, at least one extra change gear to enable a full range of metric threads to be cut, and a 5MT/3MT sleeve..
The 120/127T idler enable changing from Metric to Imperial, or vice versa, screwcutting easy;
It is a capable, and should be accurate, machine, with induction hardened bedways. The Power Cross Feed is a useful facility..
In this time, my Engineers ToolRoom BL12-24 has machined a wide range of materials and sizes, (From 10 BA bolts to cast iron over 6" diameter. ) And cut screw threads of various pitches (4mm being the coarsest )
I made a sliding Tailstock Tap holder, based on ER 25 collets..
A 80T gear for the input to the gearbox, (I made one ) will halve the feed rate, although this meant repositioning the closure for the gear cover, destroying the knob in the process, and so needing to make a new one..
HTH
