Firebox stays
Firebox stays
Home Forums Traction engines Firebox stays
  • #372010
    Maurice Cox 1
      @mauricecox1
      I recently acquired a part built Fowler showman's engine in 1 1/2" scale. It includes a silver soldered boiler which is complete except for soldering the fire box stays, inside and out. Which would it be best to do first, inside or out? Also, on each side of the fire box are five copper bushes to attach the horn plates, threaded into the inner and outer wrappers, and also wanting soldering. They are of copper, and drilled right through. I was considering making bronze ones with blind holes tapped 4B.A. Is this a reasonable idea please?
      Thanks. Maurice
      Maurice Cox 1
        @mauricecox1
        #372012
          It is easier to clamp the hornplates onto the boiler and spot through the 5 holes than try and mark out for matching 4BA clearance holes in the hornplates
        Home Forums Traction engines Topics
