I’m assuming that you do not have a copy of the pertinent M Evans book so…..
Per M Evans, Model Locomotive Boilers:
‘For model locomotive boilers from 1/2 in. to 3 in. scale, a good average height for the firebox crown is 7/64 in. above the longitudinal center line of the barrel for each inch of diameter, this figure being for boilers of the parallel barrel round-top firebox type.’
‘……If these figures are adopted, the following approximate heights for the crown above the barrel centre-line are arrived at:
……..6 in diameter parallel round-top 21/32 in.’
Note that M Evans couches his advice with the phrases ‘a good average height’ and ‘the following approximate heights’. So these are only guidelines; If I have understood correctly the increase in height in your boiler over the recommendations above is only 11/32 in (9mm). I see that the crown of Springbok is drawn as being 11/16 in. above boiler center-line so your increase over the drawn dimensions is minimal.
As regards the crown being flat…..M Evans writes:
‘it should be remembered that a plate curved so as to present its convex side to the pressure of the steam is always stronger than a flat plate, in addition a curved plate has a slightly higher heating surface. The crown of the inner firebox should therefore be made curved whenever possible.’
I have had a very quick look through some of M Evans’ boiler designs and all that I have spotted do indeed have a curve to the firebox crown, although this is sometimes very slight – for example in ‘Highlander’. There is room to add another central crown stay to the top of the Springbok firebox if you are concerned – but note the remark below about thickness of firebox wrapper. Also, or as an alternative, the design crown stays could be extended to and silver soldered to the outer boiler wrapper.
(I guess that there is a slight advantage in that your total firebox area is very slightly increased, see ‘How Many Tubes’ thread).
M Evans recommends that :
The inner firebox wrapper should not however be made unnecessarily thick, or the steam raising capacity of the boiler would suffer to some extent. If the inner wrapper is of copper or stanless steel it can be made two-thirds to three-quarters the thickness of the barrel material’ .
In the light of all this the reduced water evaporation before the crown is at risk of being uncovered is probably more pertinent. A driver of one of these locomotives might be able to give you some idea of the evaporative rate and boiler performance ‘in real life’ (rather than the theoretical rates) and thus advise you if this minor change to the design is going to have any noticeable or significant operating effect.
