Why bother with popping it in the oven. Its bright drawn mild so it isn’t heat treatable. You might remove the stresses from manufacture, but you are not going to alter its mechanical properties by that.
Put them together dry, and if they are a bit firm you could try reducing the damping (interleaf friction) with some grease, or possibly some tufnol leaves. Its all to do with the stress you operate at – there is a quite a bit of spring in mild, especially over a short travel.
I did that for my Little samson. the drawing called for spring steel – it got plain mild, and they work fine, relatively lightly (stressed) loaded over a short travel.
