Fine Gauze
Fine Gauze
Home Forums Materials Fine Gauze
  • #29997
    Speedy Builder5
      @speedybuilder5
      Small filters.
      Speedy Builder5
        @speedybuilder5
        I "lost" my piece of fine brass gauze to make a water filter ahead of a steam injector. The workshop gremlins obviously wandered off with it!
        However I am now jubilant as I found a disc or two of stainless gauze recovered from defunct cafetières. Its easy to soft solder with a 25watt soldering iron. Use phosphoric acid as the flux (Jenolite liquid rust killer).
        To make a 3/16" diameter filter, cut a piece off the disc and wrap around a 3/16" copper tube (dirty tube is best). Hold in place with a bit of cotton thread. Slide about 1/4" length off the tube and solder the joint. Slide it all off and put it back on the other way around and repeat, slowly slide each 1/4" length along and solder until done.
        #458377
        Tim Stevens
          @timstevens64731
          An alternative tube – unaffected by solder – is fibreglass – as used in the flexible tent poles which are threaded through slots in the tent.
          Just a thought
          Tim
          #458460
          DMB
            @dmb
            Speedy, well done!, good clear instructions like LBSC. Got any more good loco build tips?
            Come on, spill the beans as the great man used to say.
            DMB
              @dmb
              Tim, do you mean a piece of figlass thread poked thro' the holes?
              #458486
              Tim Stevens
                @timstevens64731
                DMB: No – the tubes used as internal tent-poles are made of fibreglass, and so are non-solderable and heat resistant. Just what you need to wrap a tube of gauze around for soldering. I make a distinction between fibreglass – a composite of resin and glass, and glass fibre – which has no resin holding the strands together.
                Some types of greenhouse watering systems also use the same sort of fibreglass tubing.
                Regards, Tim
              Home Forums Materials Topics
