Alan, Frank, Meyrick and Chris,
Thank you all for the most enlightning posts that have done much to clear the fog from my mind!
I should have added in my first post that there are indeed 2 parallel reference faces and one at right-angles – all of which were machined at the same setting along with the mainbearing housing. But not on my mill – no, its not always an ideal world!
In the meantime, I have done much to ensure that my vertical head is truly vertical to the bed; and then locked it there. I used a parallel ground block on the bed and set the DTI on the quill to inscribe an approx 4 inch diameter circle on the block, adjusting for zero run-out – or as close as I could get it – about 3/4 of a thou. (Or is there a better way of ensuring “verticality”?).
Anyway, the good news is, the mainbearing housing is, as far as I can ascertain, exactly vertical – as read by the DTI in my chuck. So, thanks to the most helpful replies on this forum, I am now able to proceed with some confidence. Thank you so much guys.
Peter
