Finally got the milling machine home.
Home Forums Model Engineer & Workshop Finally got the milling machine home.
Viewing 25 posts - 51 through 75 (of 77 total)
  • #457443
    Martin Hamilton 1
      @martinhamilton1
      Posted by old mart on 15/03/2020 19:47:43:
      If I didn't already have a large number of carbide endmills, I would be tempted to buy these, great value and not at all bad:
      I have a set of these same carbide endmills i got from Banggood, very good quality indeed & cut far far better than my branded hss cutters. Brilliant price as well makes them even sweeter.
      Steviegtr
        @steviegtr
        This evening I have purchased some cutters. Not sure if they are the correct ones. E-Bay seller. Job lot brand new. The makes are various. Says they are carbide.
        Sorry more pictures for comments. The large ones not sure how they fit or if it even if possible to fit the up to a MT2 taper. Idea's please. Also got a gallon of this stuff given , any idea what it is for. Smells like paraffin, but oily too.
        Steve.
        Edited By Steviegtr on 15/03/2020 23:28:06
        #457484
        Steviegtr
          @steviegtr
          Merlin 414 Carbide End Mills general purpose 30° Helix, centre cutting, K30, 4 Flute, TiALN Coated £28.95.
          Swiss tech ones around £25 each from googling them.
          I paid £171 for 50 of them. Works out at £3.42 each. So not bad if they are what I need. I can hold up to 16mm with the ER collets. I only have 3 collets for the Clarksone but no threaded cutters anyway.
          steve.
          Edited By Steviegtr on 15/03/2020 23:26:57
          #457485
          Steviegtr
            @steviegtr
            Sorry gone ahead of myself. I had come on to post that I tried to mill down a 250-112 toolholder & failed miserably. The H.S.S cutter would not touch it. The metal does file but not easily so pretty hard stuff. Hence me going nuts & buying those of ebay. Shd last me a while.
            Steve.
            #457513
            Alan Waddington 2
              @alanwaddington2
              Looks like a pretty good haul for £170.
              Arc sell MT shellmill arbors (To mount the big cutters on) You need to measure the hole in the cutters to determine what size you want.
              They only list 16mm and 22mm in 2MT
              #457536
                Well that lot should keep you going! Per tool, good price.
                Not all sunshine though. On my mill (WM18, 1100W, max 2250 rpm), I generally prefer HSS to carbide because the machine can't spin small diameter carbide fast enough for best results. Nor is the machine rigid enough to give big carbide cutters the welly they really need. You'll see much the same because your Tom Senior was designed long before carbide milling became widespread. As a machine it's balanced for HSS, which works best at about 20% of carbide capacity.
                Don't worry, carbide will work and although your mill is ½HP, I think it has a somewhat higher top-speed than my WM18. But it's very low compared with a machine designed for carbide. Getting the best out of it is a matter of balancing power, cutter diameter, feed-rate, depth of cut, rpm, and machine rigidity against the material being cut. Lots of variables to cope with, so don't be put off if first attempts are disappointing.
                I only have 3 carbide milling cutters. A 10mm 4-flute gets used most because it's good at roughing steel. Although it can and does produces a good finish, I usually find it easier to switch to HSS for the detail work. As always much depends on the job in hand.
                The cutters in your set most likely to disappoint are the big multi-tooth affairs:
                They're designed to remove a lot of metal quickly. Each cutting edge has to be powered through the metal, which means a big motor and a stiff machine to take the stress. A Tom Senior (or WM18) can't be expected to do super work with big carbide cutters.
                But try and see. Although carbide works best at high-power and high-speed, it often performs reasonably well on slower machines and is very convenient (can tackle materials too hard for HSS and reduces need to lubricate and for re-sharpening.)
                HSS is usually sharp with fast wearing edges. Carbide, being significantly harder and heat-resistant, is often comparatively blunt. Counter-intuitively, blunt cuts are more efficient than sharp provided enough power is behind the cutter. Blunt removes more metal faster and uses less electricity. Power efficiency is vital to industry, who also minimise downtime when tools inevitably go blunt, and like to increase the scrap value of swarf by not contaminating it with coolant.
                Industry often put thousands of watts behind a cutter and expect it to last, flat-out, for several hours. The trouble is many carbide cutters are designed with industrial service in mind, not to suit mid-20th Century HSS machines. Although there are suitable HSS-like inserts, keep in mind Carbide Catalogues bulge with less desirable to us types, some of which are unacceptably inappropriate to our machines. HSS requires much less research, and has good general-purpose slow speed characteristics well suited to hobby metalwork and classic machine tools.
                I see you've leapt straight into deep water again by attempting to mill a hardened tool-post. Practice on something easier first! The beginner needs to seduce his new tools, not crack-on regardless. There's more to learning the violin than buying a Stradivarius and having a go at Paganini's Caprices…
                smiley
                Edited By SillyOldDuffer on 16/03/2020 10:57:11
                #457544
                Anonymous
                  Posted by SillyOldDuffer on 16/03/2020 10:52:51:
                  That may well be true of inserts, it isn't true of sintered carbide endmills. The sharpness of the edge is determined by the size of the carbide particles. They're pretty small these days. When I opened my first high performance 10mm cutter bought from Cutwel I carelessly sliced my thumb open. The cutter made an incision any surgeon would have been proud of; didn't half make a mess – blood everywhere.
                  #457561
                    That said … using either two or three inserts [balanced], and running at high speed, would probably make it a useful tool.
                      The facemill people are reposting photos of will be the best of the three to use, the round insert ones will put too much strain on the machine but with the right inserts and a moderate depth of cut the other will be OK, they work on the SX2.7 so should work on the TS. I would have thought dave's Warco would also be upto using them.
                      The Swisstec may not be such a bargain as the price you quoted sounds like full retail but they are often on special with discount in the region of 60% or more eg a set of six can sell for £25. And they have never been near Switzerland either but likely to be a better quality than the unbranded ones liked to last night. They will work fine on the TS even if run at HSS speeds and cost you no more than HSS anyway, just a little care in handling needed as they can chip.
                      Edited By JasonB on 16/03/2020 13:26:01
                      #457584
                      Steviegtr
                        @steviegtr
                        Well thanks for the tips. Yes the prices is saw were from the name I googled. That pointed me at the main manufacturer , which of course would have quoted the retail price. Once they come I will try them & see where to go with them. Thanks.
                        Steve.
                        #457603
                        old mart
                          @oldmart
                          Those larger shell mills with their inserts would be best sold on ebay, as MT2 is far too small to hold them without flexing like a wet noodle. That is the reason for the dampening sleeve on your Clarkson Autolock which only holds cutters up to about 18mm, (16mm or 5/8" shanks).
                          Apart from them, you have a good lot of useful cutters.
                          Edited By old mart on 16/03/2020 16:52:41
                          #457613
                          Steviegtr
                            @steviegtr
                            So can I ask in the order of strength. Which is the weekest to strongest. I.E I take it R8 is stronger than MT2 but what above that, MT3 etc ?????? +all the old sizes .
                            Steve.
                            #457617
                            Emgee
                              @emgee
                              I believe the strength will increase as volume of metal increases because of greater diameter but that increase will depend on the quality of metal being used, not much point in a toolholder made of poor quality material.
                              For a small increase in diameter you will get considerably more stiffness.
                              Emgee
                              #457619
                              Jeff Dayman
                                @jeffdayman43397
                                Posted by Steviegtr on 16/03/2020 18:47:57:
                                Steve.
                                The question is meaningless as is. Are you talking about relative strength of holding the cutter? Tightening strength? Resistance to bending? Also the steel used and heat treatment used vary so there can not be an apples to apples comparison.
                                #457626
                                Steviegtr
                                  @steviegtr
                                  The reason I ask is because a few comments back it was said to try & use a face cutter with MT2 would be like wet pasta. So it was just to find out at what point you could use a 50mm face cutter. I think old mart did a R8 conversion on a TS. Would that suffice. Hence the question. The other comments seem to be the quality of the arbor. So made me think would say a Sandvik be so much stronger than a cheap bought item.
                                  Steve.
                                  #457634
                                    What is the size of this one? diameter and bore.
                                    Looks like a BAP 300R 50 22 6T going by the size of the plastic insert boxes that takes the APMT1135 inserts.
                                    #457640
                                    not done it yet
                                      @notdoneityet
                                      Thinking rationally about it, the morse taper fits inside the quill, so the limiting factor is the quill rigidity or the length of tool holder outside the quill.
                                      For a one horse motor, I would suggest that power is likely the limiting factor – along with that extension from the quill and quill rigidity. I would expect that an R8 in that same spindle has a very minimal advantage over MT2, if any – other than quicker/easier(?) tool changing – because the milling head components likely have more to do with the machine capability to use larger cutters.
                                      #457658
                                      Steviegtr
                                        @steviegtr
                                        Posted by JasonB on 16/03/2020 20:13:26:
                                        That one is 50mm dia . The other 2 are 63mm. Do not know the internal until they arrive. From comments though it would seem they will be no good on my machine. I would have thought the main question would be what metal you are cutting. Surely facing on aluminium would be possible & on hard steel maybe out of the question. Or am I missing something.
                                        Steve.
                                        #457679
                                        Steviegtr
                                          @steviegtr
                                          Doing some more homework, which I always hated at school. There are a lot of factors to consider to ask if a 50mm facemill could be used in a MT2 arbor. Speed, Material, feed rate. Depth of cut.The actual machine rigidity. Available drive power. Lubrication or dry. Mine is in the very rigid category but not very powerful. So like a lot of folk on here do the math. Which unfortunately I do not have the skills to, my worst subject. I see things but calculus deaf.
                                          A object as say, a piece of Aluminium. 2" square. To be faced off with some form of a milling cutter. The cutter has 1 cutting edge. Work force at that point Vs torque required to cut. 2 cutting edges . Work force at the 2 edges. 6 cutting edges. May be I am dumb but surely 6 cutters Vs 1 equals 6 times less divided into to the driving force would be the same or less than using a fly cutter which is acceptable. Am I missing something. After watching quite a few videos tonight of much lesser machines than mine doing a dam fine job with multipoint face mills makes me wonder what advice I am listening to, theory or actual experience of doing said work. I truly hope it is from experience & not just your idea of what it might be.
                                          Steve.
                                          #457684
                                          Ron Laden
                                            @ronladen17547
                                            One tool I would recommend (from experience) which should be fine in MT2 and your available power on the TS is the 25mm – 2 insert end mill from ARC. I use one on my small SX2P (500 watt) R8 mill. Since getting one it is probably my most used cutter, 1604 polished inserts for alu and Tin coated for steels. Available in MT2 at £29.98 and I have found it to be excellent.
                                            #457687
                                              As I said earlier with the right inserts in this case aluminium specific ones and a modest depth of cut say 0.5mm to start with I can't see an issue with trying the 50mm head on a MT2 arbor, I'm sure many here would have run MT2 flycutters swinging a 2" diameter at the cutter tip so not much of a difference.
                                              The question of single tooth or six tooth, the six tooth will put more load on the machine if you load each tooth the same as if you took a full width cut off your 2" block at say 0.002" per tooth you could have two or 3 teeth cutting so 0.006 load (not quite that but beyond this discussion) but if you simply run the carbide faster than the common HSS flycutter and feed at the same rate the chip load will come back down so no more load and possibly less than a single point fly cutter. Added bonus is the facemill will be better balanced than a flycutter too.
                                              #457691
                                              Martin of Wick
                                                @martinofwick
                                                Just do it… you will soon find out the optimum feed and speed for your face cutter and application. You don't need to have the best of the best, or the biggest of the biggest for hobby work. If in the end it doesn't remove sufficient cubic inches of metal per minute to meet your expectation, then you will need a bigger mill.
                                                If it is of any help I use 43 and 50mm multi tooth face cutters with no problem on a WM16 with MT2 – not a rigid or powerful machine by any standards. Try 0 .5mm on ferrous and 1.0mm DOC on non ferrous say 0.,05 mm chip load at maximum RPM as a start (only 2500 rpm on the W16). I generally prefer these multi tooth jobs to single point fly cutters.
                                                I would have thought that the TS could probably do better than a WM16, being a more substantial machine.
                                                #457696
                                                Simon Williams 3
                                                  @simonwilliams3
                                                  'ang on a minute chaps.
                                                  All this stuff about stiffness of the spindle is irrelevant – the power you can get to the cutter is limited by the drive belt. For those not familiar with the TS light vertical head,, it uses a Z section (3/8 wide) vee belt, 500 mm long. With only a slide and clamp tensioner. Modifications could be made, but they'd be fundamental to get a bigger belt and or a screw tensioner in the mix.
                                                  FWIW I use a 40 mm diameter shell mill with APTK1604 inserts, depth of cut about 0.5 mm and feed pretty gentle, as you don't want the cutter to stall 'cos it chips. You can use the cutter in either of the two bottom speeds (approx. 200 and 400 revs) – it makes no never mind just so long as the cutter keeps cutting freely.
                                                  The amount of metal you can shift is limited by the power at the cutting edge, not the stiffness of the machine.
                                                  My cutter arbour is MT2, yes it would be nice if it was stiffer but that ain't the limiting factor.
                                                  It's a light vertical!
                                                  Rgds Simon
                                                  #457707
                                                    Posted by Steviegtr on 17/03/2020 02:01:37:.
                                                    …May be I am dumb but surely 6 cutters Vs 1 equals 6 times less divided into to the driving force would be the same or less than using a fly cutter which is acceptable. Am I missing something. …
                                                    Steve.
                                                    Not dumb at all, but much depends on how the operator uses the tool. A multi-cutters design purpose is to remove metal quickly. To do that it's pushed at high feed-rate into the metal. To get the intended metal removal rate, a fast powerful rigid machine is needed. That's what's industry have. A fly-cutter does the same job more slowly and is suited to small bendy machines.
                                                    But there's no law saying tools must be used exactly as their designer intended. Due to the limitations of home workshops, a Model Engineer probably won't be able to drive a multi-cutter to it's full potential. It still cuts at reduced speed and power but it won't remove metal as well as it might. Could be 'good enough'.
                                                    Hence the apparent contradictions. A Tool Catalogue will describe the conditions under which industry will get the best out of a cutter; their goal is making items as cheaply as possible, which means carefully balancing metal-removal rate, tool-life, and power-consumption. That generally means carbide cutters making very fast deep cuts with rigid powerful machines.
                                                    But an amateur can put the same cutter in his relatively weedy machine and still get reasonable results from it. Or not!
                                                    How the tool behaves at a particular time in a particular workshop depends on a multitude of factors that are rarely explained by home users. What machine, how much power, depth of cut, feed-rate, material all left in the fog. We don't know what inserts are fitted to your cutter. So reports of the same tool vary from 'complete rubbish' to 'excellent' because, when used off-specification, performance isn't predictable. It depends. It's more obviously unfruitful to compare the performance of a family hatchback with a Farm Tractor or a Formula 1 Race Car without mentioning how they will be used!
                                                    The same issue applies to machine tools. For example, Stevies Tom Senior mill was aimed at the precision end of the market. It features high-rigidity with a smallish motor in order to improve basic accuracy, a good thing. It was never intended to hack metal in the shortest possible time, and, although the machine could be up-motored to do that, may not be an improvement.
                                                    To find out how well your cutter works on your machine, it's necessary to try it. Depending on context it may or may not be suitable. If bought to remove metal at high-speed, it will disappoint because a ½HP motor simply isn't powerful enough to drive it. However, run gently within the limitations of slow or small machines, some report they produce a better finish than a fly-cutter.
                                                    All this is liable to confuse the beginner! I found the best approach was to read books, ask questions, and then use tools to make things. I found using tools to be absolutely essential, because it's so easy to miss important hints in books and forum answers. Experience + Theory = Understanding.
                                                    Fortunately, getting a feel for tools and materials isn't Rocket Science. Pragmatism works too, it just takes longer and may form bad habits. Start points can often be decided by rule of thumb, and then adjusted up or down for best results. For example, I determine RPM by dividing 10000 by the diameter in millimetres. The answer is about right for HSS and Mild-Steel. Double or triple RPM for carbide, and increase or decrease by a factor to suit the metal relative to steel. Then, on the machine, tweak RPM for best results. It soon becomes second nature, and – knowing how ordinary materials behave – makes it much easier to deal with hardened or otherwise awkward metals. And experience revealing what the machine can do makes it much easier to decide on modifications and tooling.
                                                    old mart
                                                      @oldmart
                                                      Regarding stiffness between R8 and Morse tapers, I would expect MT4 to be equivalent to R8. ISO30 and above are stiffer, the general industry standard is BT/ISO 40. The advantage of any dedicated milling spindle is the steeper angle, making removal much easier than Morse tapers.
                                                      If that 50mm six insert shell mill does take APMT11 size inserts, then get some of the cheap Chinese inserts intended for aluminium. They are sharp and will lower the cutting forces substantially when used on aluminium, don't forget to use a little WD40 or similar. I would not use a shell mill more than 40mm diameter on steel on a Light Vertical.
                                                      Edited By old mart on 17/03/2020 10:33:48
                                                      Edited By old mart on 17/03/2020 12:52:00
