Posted by Howard Lewis on 10/02/2023 18:19:01:
Really there should be an On/Off switch of adequate capacity, (About 3 Kw to cope with starting currents, so ideally a NVR ) wired between the supply and the Dewhusrt swithch.
Have to admit that when I had my at least secondhand ML7 used the Dewhurst to start (But only when the spindle was stationary, ) and stop and never had any trouble.
With respect, 3 kW is not correct.
I suspect that the motor is 1/3 h.p. so it will draw 1 amp under load and up to 6 A briefly on starting. A Dewhurst switch will certainly cope with that.
I never had a problem with mine on an S7 so a slightly bigger motor.
The advantages of a separate NVR switch are (a) if the power is cut, the motor will not start up again unexpectedly when the power is restored; and (b) there is the option of an emergency stop mushroom button. However, it is certainly not a necessity.
It looks lovely – enjoy it!
Edited By Chris Pearson 1 on 11/02/2023 11:22:54
