Filing Machine
Filing Machine
Home Forums Manual machine tools Filing Machine
Viewing 3 posts - 26 through 28 (of 28 total)
  • #55842
    Ian S C
      @iansc
      Its a while ago but the file sections would have been about 4″ long X 1/2″ wide X 1/4″ thick, the wheels top and bottom proberbly 18″ dia, It would be used in a similar way to a linishing machine/ belt sander. The only lathe they had at the time was about 6ft between centers, with 18″ chucks, in very good nick, but just a little on the large size.Ian S C
      Billy Mills
        @billymills
         Axel
        The Proxxon MBS240 mini bandsaw has a diamond blade option -needs a water drip tank for the coated blade. Not cheap but useful for miniature work.
        Alan.
        #56077
        Chris Trice
          @christrice43267
          I built a filing machine many years ago powered by a windscreen wiper motor. It had more than enough grunt to do what I wanted and could’ve broken fingers if you weren’t careful. The file was a 12″ long 1/4″ round file supported at both ends by being pressed into two short lengths of drilled steel bar (think conrod but with a piston at both ends). The steel bars slid within blocks of brass bored to match the bar which in turn were secured to a steel surface. Power came from a hefty mains transformer. The reciprocating speed of the wiper motor was just about perfect for filing.
