Hi,
I was watching the video posted by Jason of the guy making a ring from a couple of brass nuts. I noticed he was filing the ring by starting with his left hand high, and following the curve with his left hand dropping as he pushed forward. This seems to be the usual procedure for most if not all of the people I see filing curves which is not surprising as it is the natural way of doing it.
When I was taught workshop practice at the Tech however, the tutor went to a lot of trouble to stop the class doing it that way. He taught us to start a cut with the left hand low, and to raise it as the file was pushed forward. There was a lot of muttering about it initially, but once the technique was mastered, it seemed to give better results, although this may have been because we were getting a lot of practice in filing.
Is the way I was taught the "correct" way or doesn't it matter which way it is done. The guy making the ring certainly ended up with a nice curve.
Alan
